Old 10-13-2017, 10:51 PM   #1
Joe Schweigert
Joe Schweigert's Avatar
Liked 19 Times in 8 Posts
Default Re: Best shifter for metric 200
I have had my Precision shifter since the day I made a Super Stocker out of it. Always worked perfectly. Never had to touch it. Been using it since 2007? Maybe somebody could clue me in on the maintenance you have been doing? Sounds like I have been lax.
Thanks!
Ed I just lube the moving parts silicone spray or other spray lube I would not rec white grease tends to attract dirt
Joe Schweigert 751 SS
Joe Schweigert is offline   Reply With Quote
Old 10-13-2017, 11:38 PM   #2
Ed Wright
Ed Wright's Avatar
Thank you Joe!!
Ed Wright 4156 SS/JA
Old 10-13-2017, 11:55 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
The only problem I ever had with the PPP was operator error. You have to adjust the cable with the shifter in second gear...if careless it is easy to move the shifter handle from it's optimal position by snagging the cable end under the car. I now double check the shifter every time when swapping/replacing the transmission.
Rich Taylor
I/SA - 321
Old 10-14-2017, 10:10 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
90%Of the S/SS cars I work on in my shop either have the Cheetah shifter or are getting one installed .
I drove a DragPak Challenger I built with PPP shifter and had trouble with shifting right thru second gear .
Operator problem , Yes . My big clumsy hand kept hitting the trigger ! .....But I've never had that problem with any Cheetah equipped car I drove.
Old 10-14-2017, 11:15 AM   #5
Ed Wright
Ed Wright's Avatar
I always check the cable adjustment when putting the eng & trans back in the car. Mine is shifted by air. So far it has been flawless.
Old 10-14-2017, 11:34 AM   #6
Signman
Liked 269 Times in 99 Posts
The Turbo Action shifter is great but not so good with manual shift reverse pattern valve body. Very easy to slip from 2nd to 3rd. Did it many times had enough.
Precision shifter is the best, a little spray now and then if it gets stiff. Once in low gear each shift is just hitting the handle with you palm nothing more. Don't keep your hand on or hold it, after each shift it needs to reset to be ready to hit it again on the next gear change.
With any shifter you choose proper adjustment is required when installing any transmission just to avoid dumb stuff we all run in to anyway.
Old 10-15-2017, 08:06 PM   #7
Eman
Liked 133 Times in 76 Posts
On the maintenance side....I never would have believed how much the cable resistance was after years of no lube. Shifter worked but not like it should. I removed the cable and sprayed cable lube in it so it ran down to the bottom and it really freed it up. I tried one of those motorcycle cable lube tools but the cable is too thick. that would be the trick for in the car lube.
