#51 | |
Liked 1,832 Times in 428 Posts
Because of this the old cars will Never catch up Indy is where you should be able to make a NEW ad get hp hit This Is a problem. But most of you are drunk on the Koolaid
james perrone 1290 STK |
#52 | |
Liked 21 Times in 7 Posts
He bought 100% original parts, including cam, carb, heads, etc. because for some reason it mattered to him that it was all original.....even though the pistons were knurled, the valves were sunk to China, the block was ridge-reamed, and on and on. It made 570 HP on a DTS dyno with a set of Hooker street car headers. |
#53 | |
Liked 2,354 Times in 554 Posts
#54 | |
Liked 652 Times in 184 Posts
Your right it doesn't matter at Indy . I was talking just in general . Nothing will change anyway.
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA |
#55 |
Liked 20 Times in 14 Posts
So what car or cars are we talking about here???
#56 |
Liked 10,804 Times in 2,245 Posts
376/426hp 15 Camaro.
#57 |
Thanks Larry. How many of these cars are going to indy?
#58 |
Liked 129 Times in 59 Posts
Isn't it the 2015 Camaro 2dr Coupe with the 376/365 horsepower combination? It was 426 horsepower in the 2010 Camaro at 3849 pounds.
Lew Silverman #2070 "The Wagon Master" N/SA |
#59 |
My bad, the engine specs for the 15 engine are better than the 2010 376 / 426 engine. I must have look at the incorrect window while comparing the two engines. 3849# I thought they were in the two ton range, not the 3150# of the 15 Camaro
#60 | |
The base weight is 3320. And no, a zero option 1SS doesn't weigh two tons. I would love to know what a stripped Challenger weighs. |
