Old 05-23-2017, 12:44 PM   #1
Mike Pearson
Mike Pearson's Avatar
Liked 1,937 Times in 582 Posts
Default Re: Valve Tulipping
Originally Posted by voltdr View Post
We agree that titanium is better but, according to the cylinder head specialists Brodix, they aren't required. Bordix is even at a loss as to what happened.The real question I had is what caused the valve to tulip?
Dan
Probably just a couple of bad valves. I have had bad luck lately with Manley SS exhaust valves. I have had 2 exhaust valves drop the heads off and destroy 2 good engines in the past couple of years. The last set only had about 75 runs on then. These are small diameter valves too. I guess I will start to change the valves at 50 runs from now on. The Manley stuff does not seem to be as good as it used to be.
Mike Pearson 2485 SS
Old 05-31-2017, 09:16 AM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Detonation causes tuliped intake valves.....
It also can show up as top ring land excessive wear and obvious damage to the pistons above the top ring.
Bad gas, to much timing.....some sort of timing malfunction during a run that allows timing to advance with RPM....
I had a digital box once that advanced the timing to over 70 degrees once the engine started.....Holley Annihilator.......!!! Took me 3 tries to get one of those boxes that worked.....
Rich Biebel
S/C 1479
Stock 147R
Old 05-31-2017, 10:19 PM   #3
voltdr
Liked 100 Times in 51 Posts
Thanks Rich. When I put it back together I will check the timing again and see if it changes as the RPMs increase. I also added the ability to move my O2 sensors (2) to each cylinder to keep better track of the mixture.
Dan
voltdr is offline   Reply With Quote
