View Poll Results: Fuel injection? Do you run in open loop or closed loop | |||
Open Loop |
80 | 65.04% |
Closed Loop |
43 | 34.96% |
Voters: 123. You may not vote on this poll |
Thread Tools | Display Modes |
#121 | |
Liked 27 Times in 6 Posts
I suggest that you clean up the drivability area of your fuel table, then either put it in Open Loop, or set the closed loop to turn on about 300 rpms above your converter flash RPM.
David Page Fuel Air Spark Technology (FAST) |
#122 | |
Liked 70 Times in 31 Posts
It sounds like OL will offer most consistency. Do you agree? Thanks again!
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
#123 | |
I would work on my idle and part throttle. I like my plugs clean.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 05-11-2017 at 03:03 PM. |
#124 |
Thanks again Ed and to all of you. I really do appreciate all the help!
#125 | |
The 2 step has a similar effect. Misfires from the rev limiter put oxygen in the exhaust, which looks lean to the wideband & ECU as well. Mine shows over 15-1 sitting on the starting line, on the 2 step. If in Closed Loop there, it gets so rich it won't leave. My converter flashed to 6200, air/fuel doesn't clean up until 6500/6600. I think it would be making false corrections below that. So, I can't enable Closed Loop until 7000. My VE table has 500 RPM breakpoints. I have worked on my fueling until it never makes over a one percent correction in Closed Loop now. Might see what David says about this, but it has worked for me.
Ed Wright 4156 SS/JA |
#126 |
Forgot to add: David (pretty sure it was David, I'm old) told me I should put my O2 sensor in a primary tube, for corrections from Idle & up.
I have since had mine on Patterson's dyno, with eight O2 sensors. I run mine in sequential mode, so I can correct each cylinder. Now, the sensor in one primary on each side should be fine. I had nearly a 5% spread between cylinders before. They are all very close to identical now. After having run at all the tracks in our area, I log the first pass at each track now, never have had to touch it the last couple of years. Much simpler than running a carb.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 06-16-2017 at 08:50 AM. Reason: Still can't type. |
#127 |
The Holley system will not allow closed loop on the 2 step. Closed loop happens at about 4500 rpm off the two step. My Camaro qualified better than usual in Denver but my Firebird wouldn't run the index today in Super Stock. Not sure if it's broke or I just don't have the tune right. I leaned it to 13.1 from 12.7 after 6000 rpm (per suggestion from Duane Dickens) for last qualifier in the morning so we'll see. Thanks again!
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com Last edited by Darrel Goheen; 06-18-2017 at 11:31 PM. |
#128 |
13-1 is not lean at all "up there" at Denver. I would try 13.5-1. I'm surprised it likes 12.7-1 best at sea level. But, wide bands don't always give the same numbers. Be nice if they did. I bought a stand alone wide band set up so I could log both banks. Bought from the same people as the first. My original deal showed 12.9-1, the new one 12.5-1. Put it on Patterson's dyno with a wide band in each primary tube. Not that far off. Moved my original wide band to the other collector on the dyno. Both sides the same. In the car, one side still showed richer. Swapped sides with the original ECU wideband & the add-on, rich side moved too.
#129 |
I ran .03 under the index far enough yesterday morning in the last qualifying round after advancing the timing two degrees and leaning it out per Duane's suggestion. Why does does high altitude like a leaner AFR? I may try leaning it out more at this weekends race but it's tough to tell anything when you only get two time trials before eliminations. Thanks again Ed. I ain't giving up yet!
#130 | |
Liked 782 Times in 195 Posts
