Liked 54 Times in 24 Posts
I had one customers' engine that I tore down for a freshen up only to find multiple spiro loc failures. To the point of serious cylinder wall and piston damage. After digging for info I found out the previous assembler purchased his spiro locs in bulk from McMaster Carr. Needless to say the quality control ( heat treat ) may not be up to the quality of that of a Performance Piston company. I installed JE locks and 2 seasons later on freshen up, no more failures on a 700" .
I am not suggesting that that toolmakeron's engine has McMaster stuff in it, just sharing an experience*
Todd Gross 3323 FS/E,F |
Liked 26 Times in 11 Posts
Ron,
You are going to have to trust me on this, and all the "experts" on here are going to piss and moan. You need to have more pin end play. The reason the other engine opened up to .035" is because that's what it wanted. The pistons deflect from gas pressure and the pin bosses flex inward. We built a fixture and we put 1500 psi nitrogen on top of a room temperature piston just to prove this fact. Lost numerous cup engines and a few IRL engines as well, with too tight of wristpin end play. Wristpin end play is like bearing clearance, too much and you know about it, too little and everybody knows about it. See you at the races, Wayne Kerr |
#3 | |
Liked 704 Times in 281 Posts
Good morning Jeff,
There are certainly many factors that are in play here. The first is piston design, the new "Box bridge design" pistons are reinforced in the pin boss area and can run less wristpin end clearance. .025" would be adequate for that type of piston while the old full round pistons like a Venolia, I would like to see .040"+ Bore size will play a role as well, bigger bore, more piston deflection. See you at the races, Wayne Kerr |
#5 | |
Liked 99 Times in 49 Posts
Liked 192 Times in 83 Posts
Simple question.. how much vacuum are you pulling??.. too much vacuum will affect oiling to the wrist pins, and possible damage... just an idea..
Just use a regular one inch travel dial indicator, with an extension. Welding rod for the extension will suffice.
