#31 | |
Liked 13 Times in 11 Posts
You cant be happy with 1.40s 60s ![]() Oh yeah , almost forgot.I have Chassis Works "floaters' on mine too.............with mono leafs. The car was built in early 90s. Last edited by joespanova; 04-20-2017 at 11:12 PM. |
#32 |
Liked 520 Times in 132 Posts
I have a 3.19 with a 6.17 at 3025lbs. 2.98 isn't enough IMO
#33 |
Banned
Liked 179 Times in 89 Posts
#34 |
Dana 60 current ring and pinion has about 70 runs on it.
#35 | |
Liked 1,943 Times in 584 Posts
Mike Pearson 2485 SS |
#36 | |
#37 |
I have a 1.96 low in the glide and a 5.86 in the rear with a 100 inch roll out radial tire. The glide is handicapping me a bit in comparison to the 3 speed cars I suspect I could pick up about .015 with a good 3 speed trans. I have the power but cant run the short times of some of the really fast cars in my class. I have run next to those guys and their short times blew my mind.
#38 |
Liked 311 Times in 175 Posts
I always thought the Santhuff's fronts big difference was their compression valving, controlling the car after it comes down from a large wheel stand. Are their rebound qualities equally unique?
#39 |
Sorry I never asked what combo and class do you run? Ed
#40 |
I run nostalgia SS and FX stuff........not current traditional stuff like you're doing but fun none the less......still a lot of work though , mainly because I do everything myself , engines , trans , rear end etc etc........and the body aint what it used to be and is very sore at the end of the day.
A 377 is in the car now but I've been a 9.41@ 141 with the ol' 355......but that engine would vary from that best to a low .60 high .50. 23 degree std runner head. The 377 is the same engine basically , just the 4.155 bore and more compression. Same heads , cam , intake etc etc. This is an old video..........I've posted here before , but here it is ..this was with the 355......9.51, 139ish. Launch RPM was realtively low this day IIRC I expect the 377 to get me in the 9.30s in good conditions. |
