Old 04-15-2017, 08:14 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default alternator problem
I have a late model fuel injected lt1. My alternator has a 60 amp inline fuse with a #10 wire back to the battery. It keeps blowing the fuse at random times. I am not to good at wiring. any suggestions on where to start? It is a nice B/SA car. do i have to run the alternator? could alternator be bad? I have checked the wire and dont see any bad spots but thats what i am leaning to. New car for me. I have 0 passes in the car. Thanks for any advice.
Kdw1403 is offline   Reply With Quote
Old 04-15-2017, 08:21 PM   #2
Keith 944
Keith 944's Avatar
Default Re: alternator problem
I had a 100 amp alt w/8 gauge wire and it was ok when I changed to a 160 amp msd alt. it melted the fuse holder and wire was hot! I changed to a 4 gauge wire and a circuit breaker problem solved. So even if it is not an issue now I would go to a much larger wire...
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 04-15-2017, 08:45 PM   #3
SST3193
Liked 2 Times in 2 Posts
Look up online the ampacity of 10 awg and you will find it can only handle 30 amps. 4 awg is on the border, if the battery gets very low but , should be OK.
SST3193 is offline   Reply With Quote
Old 04-16-2017, 11:18 AM   #4
pmrphil
Liked 348 Times in 152 Posts
Originally Posted by sst3193 View Post
look up online the ampacity of 10 awg and you will find it can only handle 30 amps. 4 awg is on the border, if the battery gets very low but , should be ok.
bingo !!!
Phil Molski
PMR Performance
S/C 1623
Old 04-17-2017, 10:51 AM   #5
cmracing
Liked 62 Times in 29 Posts
How is your car wired? Do you have a Ford starter relay up front? I use #2 wire between my alternators and Ford relay. From the Ford relay is 00 welding cable. I have no voltage drop from the back of the alternator to the battery (which is in the back).
Use at least a #4 wire, but bigger is better. If it is simply going from the alternator to a front-mounted battery, #4 will be good, #6 would even work for that short (pun intended) of a distance.
Throw that #10 in the garbage.
cmracing is offline   Reply With Quote
Old 04-17-2017, 12:18 PM   #6
HR9121
HR9121's Avatar
One of your other questions, yes you do have to run the altenator if you run Stock eliminator.
James Williamson
W200 J/SA. SS/JA
