Old 03-26-2017, 02:58 PM   #1
ken robinson
Liked 224 Times in 87 Posts
Default Average RPM slippage on a conv
Whats the average rule of conv. slippage = in RPM +/- ? I'm trying to see what the top end RPM is with different rear gear ratio's .... RPM x tire dia. / by MPH X 336 = ring & pinion ratio . That formula dosen't account for conv. slippage , and is giving me the wrong gear ratios ....The car goes thru at 6750 x 28 tire / average 115 mph x 336 = 4:85 gear . But thats not true because it runs a 4:30 not a 4:85 . What would it go though with 4
:56 like 7150 rpm in average air ? My math / formula is wrong or I'm missing some thing .
Old 03-26-2017, 03:53 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Average RPM slippage on a conv
Also if you have bias ply slicks you get some tire growth . Radials not so much .
Old 03-26-2017, 07:03 PM   #3
GTX JOHN
Liked 2,487 Times in 698 Posts
Hard to put a number on slippage from this little info.....Converters vary
greatly. MY best advise is just trial and error if you do
not have a Data Monitoring System to fall back on.
John Irving
741 Stock
741 Super Stock
GTX JOHN is online now   Reply With Quote
Old 03-26-2017, 08:01 PM   #4
S/ST 3040
S/ST 3040's Avatar
115 x 4.30 x 336 / 28 = 5934 RPM (drive shaft RPM)
5934 x 100 = 593400 / 6750 = 87.9% (or 12.09% slippage)
115 x 4.56 x 336 / 28 = 6293 (drive shaft RPM)
6290 / .879 = 7159 RPM
The 4.56 gear should let the converter show better efficiency but, no way of knowing
exactly how much. Like was already stated, tire growth will affect the final number.
S/ST 3040 is offline   Reply With Quote
Old 04-11-2017, 10:27 PM   #5
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
5% slippage is a good number to shoot for.
Old 04-14-2017, 06:38 PM   #6
jaf2021
Liked 5 Times in 5 Posts
What if your % is 112?
jaf2021 is offline   Reply With Quote
Old 04-14-2017, 09:39 PM   #7
Dyno
Dyno's Avatar
you are slipping 12 %
Old 04-15-2017, 09:10 AM   #8
jaf2021
Converter too loose????
I would have to double check but I think there is about a 1200 RPM drop between gear change(PG)
Old 04-15-2017, 12:24 PM   #9
Ken, Ever try a 4.10 with that converter?
Old 04-16-2017, 11:55 AM   #10
ken robinson
I have not tried the 410 gear yet . I need to try the lower 1st gear before I try the 410 . Its a low rpm torque combo mainly so I see your point Mark . Thanks
