#11 | |
Liked 311 Times in 175 Posts
#12 |
Liked 23 Times in 14 Posts
Thank you for the advice guys, seems a majority is to keep the C4 - this does save me some money to spend elsewhere.
Marty
Marty H |
#13 |
Liked 431 Times in 224 Posts
Yep, 468 BBC on alcohol. I figure it is just a little under 700 hp.
S/ST 51 S/C 53 |
#14 | |
If you dont mind me asking, how are you approaching the Stop set-up with the 3 speeds? Are you running t stop in 1st gear or 2nd gear? How low in the run is the stop coming on for them? Have a friend who may dabble in this who runs a heavy S/P car (SBC) with a Flying toilet injection system and a 3 speed. Runs 10.60's in 1/4 at 123. We dont run 3 speeds s I'm curious what others are doing with them and the stop? Thanks, Andrew |
#15 |
Liked 262 Times in 124 Posts
I'm on the stop at 020 and its on for usually between 1.70 to 2.10 then it shifts into second. My car runs 10.teens usually. I here that toilets have to be shut back to idle to work well?
#16 |
Sorry to high jack the thread, but has anyone ever experienced a much slower rollout when swapping first gear in a powerglide ? Say 1.98 to 1.80 . Thanks guys
#17 |
Liked 705 Times in 282 Posts
To bad I'm in AZ I have a B&M 1.98 glide ,w/brake. Bell housing cracked and welded. Install and dedenbear bell housing and your set. $900 plus shipping which wouldn't make it feasible.
