Old 02-05-2017, 11:05 AM   #1
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
Default 66 Chevy II and a Powerglide
So it appears that a Glide with a SFI shield wont fit in the tunnel on a 66 Chevy II? Anyone? Thanks.
Old 02-05-2017, 11:23 AM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: 66 Chevy II and a Powerglide
It's a bummer , but either redo the tunnel , or swap to a certified case and bellhousing .
Old 02-05-2017, 12:46 PM   #3
ZenzenRacing
Liked 53 Times in 17 Posts
I have a Rossler that doesn't need a shield !!
ZenzenRacing is offline   Reply With Quote
Old 02-05-2017, 07:29 PM   #4
jerry witzel
jerry witzel's Avatar
Liked 44 Times in 15 Posts
When I had my Chevy 2 I bought a CSI super shield. Somehow I got it put on once. The next time I pulled the trans I fought and fought that thing. I ended up throwing it in the corner where it laid untill I put my Camaro together. It fits on it but makes trans and engine swaps quite interesting.
Old 02-05-2017, 07:47 PM   #5
tommy d
tommy d's Avatar
You running a ''good '' case? I'm just gonna swap the internals to a SFI case.
Old 02-05-2017, 08:04 PM   #6
tommy d
tommy d's Avatar
Thanks for the help guys.
Old 02-05-2017, 08:23 PM   #7
James Perrone
Liked 1,830 Times in 428 Posts
I have no problem in my 67 nova. Use a tci shield. Jw. Bell
james perrone 1290 STK
James Perrone is online now   Reply With Quote
Old 02-05-2017, 10:20 PM   #8
tommy d
tommy d's Avatar
With no floor mods?
Old 02-06-2017, 08:11 AM   #9
nhramnl
Liked 358 Times in 83 Posts
I tried installing a TCI flexplate shield on a stock case PG for HOURS the last time I reinstalled the engine in a '66 Nova. I bent it, cut it, and actually removed parts of it, until there was so little left that it didn't even look like what it was. It was in a box of loose parts I was given when I bought the car, and that experience made it clear why. However, a TCI aluminum trans shield (the unit that covers the "body" of the transmission) would fit.
Old 02-06-2017, 09:11 PM   #10
Jrscamaro67
Jrscamaro67's Avatar
Ran into the same problem..put a Jw bell and a trans blanket on for the current fix til i upgrade trans case
Jrscamaro67 is offline   Reply With Quote
