Old 01-28-2017, 12:42 AM   #1
Dave Gantz
Liked 251 Times in 125 Posts
Red face Re: 1966 Coronet stocker
Originally Posted by Dave Gantz View Post
So, it's back on? Your previous post says you aren't doing it.
To quote Emily Litella; "Never mind".
Hope it's going well.
Old 01-28-2017, 09:39 PM   #2
Spyphish
Liked 679 Times in 180 Posts
Default Re: 1966 Coronet stocker
It's an ugly male, and thanks to Frito for finding it. Radio delete panel worth more than the whole car. Will try to use it at D4 event to get a grade point. At least 11 second street car. Phish
ID:	38102   Click image for larger version
ID:	38103   Click image for larger version
Old 01-29-2017, 11:20 AM   #3
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Like the car a LOT.....but that tach has got to go!
I'll see you at the start of the race...
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 01-29-2017, 04:01 PM   #4
Rag71
Liked 9 Times in 5 Posts
What was car originally?Saw a brown 4dr hemi in the early 80's in southern ontario .Was ordered by a veterinarian .
Rag71 is offline   Reply With Quote
Old 02-10-2017, 07:41 PM   #5
Spyphish
The sintered iron disc clutch has come out as it is un-streetable. Correct Ram setup on the way. That top thing-a-ma-jig is a Timewise electro magnetic precision rally speedometer. The tach off to the left will be taped covered as well as the stock speedometer. Look for a couple of nuts dressed as the Blues Brothers in an old cop car. See you there.
Old 03-21-2019, 09:57 AM   #6
Spyphish
Finally after two years of non use, we have installed a Passion 5 speed. Excellent engineering and 5th gear (OD) 2000 rpm is over 60 MPH with a 4:10 gear. Another team will run this years Great Race Riverside, Ca. to Tacoma in late June. Hope to see you on the route. Probably the quickest car in the race. FBIPhish
Old 03-21-2019, 11:14 AM   #7
Hacksaw
Liked 314 Times in 177 Posts
Is that an A-833 Mopar trans reworked?
Old 03-21-2019, 12:03 PM   #8
Spyphish
Nope, Jammie Passion builds them from scratch and you do NOT have to cut up your car. Bolt in 5 speed. But long wait list but worth it. Passion Performance
