Old 12-22-2016, 12:42 AM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: '67 El Camino H/SA
Moving at a snail's pace as usual. Ford housing ends to be welded in place Friday, then I can order axles and get the 12-bolt back under the truck.
Rich Taylor
I/SA - 321
Old 12-23-2016, 07:41 PM   #2
HandOverFist
Thanks to Perry Simpkins and Gary Jennings, no more c-clip eliminators.
Rich Taylor
I/SA - 321
Old 12-24-2016, 04:33 PM   #3
HandOverFist
New Budnick steering wheel looks right at home in there.
Rich Taylor
I/SA - 321
Old 01-24-2017, 03:01 AM   #4
HandOverFist
Best I could come up with for an alternator/mount...a lower mount was just not working out.
Ordered the wrong Wilwood rear brakes for my housing ends...awaiting replacements so I can stab the axles in and measure for back wheels. Also need to fabricate a d-shaft loop which will likely get welded to the crossmember.
Rich Taylor
I/SA - 321
Old 01-24-2017, 12:08 PM   #5
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Lookin' good!
I have the same alternator mount on my bracket Camaro, but I had to extend the top part a bit when I got tall valve covers. But I like it a lot, it's easy to get the exact tension on the belt you want and it holds it great.
Dave Muller is offline   Reply With Quote
Old 01-24-2017, 12:28 PM   #6
HandOverFist
It needed two 1/4" spacers to line the pulleys up...running a 46" belt.
Rich Taylor
I/SA - 321
Old 01-24-2017, 09:19 PM   #7
Alan Nyhus
Liked 799 Times in 236 Posts
Rich, Ram Air Restoration offers a driveshaft loop that bolts to the Chevelle cross member. -Al
http://www.ebay.com/itm/PONTIAC-OLDS...isMfNg&vxp=mtr
"That'll never work....."
