Liked 584 Times in 94 Posts
My recommendation would be to use IHRA Classes and Indexes. You'll solve about 75% of problems, in advance, keeping the Older Carburetor cars separated from the Newer Fuel Injected cars. I would also combine sticks and autos into the same class.
#2 | |
Liked 373 Times in 131 Posts
I cannot seeing one single NHRA racer not liking the idea of getting an extra 3 tenths advantage during qualifying. However, keeping the carbed cars separate from the EFI cars may not work because NHRA has equivalent classes for the EFI cars. Either way, I would enter my EFI T-Bird as an IHRA car because the factored hp is less in IHRA for the same combo, therefore less weight I have to tug around. ![]()
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#3 | |
Liked 27 Times in 14 Posts
On a separate note, I'm not sure I understand how "weight" will not be a technical requirement. Maybe someone can clarify! In terms of the heads up, I think it could work. Basically, as long as you run your car within 0.10 of "wide open" at all times, you should be able to cover your "heads up dial-in". Bottom line, with this scenario, the faster car will most likely still win. |
#4 | |
Liked 84 Times in 42 Posts
We run both IHRA and NHRA but do not have the advantage of the .3 easier index in IHRA because we have one of the dreaded new cars, even though ours is pretty much a stock combo. In fact, it is backwards NHRA FS/H - 11.50, IHRA DD/FIA - 11.30 We do get to take 165 lbs. out in IHRA but we can't get it out anyway so we don't bother. In the end qualifying, unless you are #1, doesn't mean a whole lot.
Bob Tilton 568 FS/H |
#5 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
I see the first NMCA race at Bradenton will be on the same date as the Gainesville D2 race right before the Gators. Won't be any S/SS NHRA cars there (Bradenton). That's a shame. Schedule change in order? Jim
Liked 33 Times in 16 Posts
You won't see a schedule change on NMCA's end...that was finalized before this class was created/added.
Rich Taylor I/SA - 321 |
Liked 67 Times in 27 Posts
Liked 7 Times in 4 Posts
Does anyone know if this class is being ran with
NMCA west ? I can't find anything on thier site.
Bob Aceves, 746 E/SA A&M motorsports |
Probably not Bob...that is a separate entity.
