#31 | |
Liked 23 Times in 13 Posts
Frank Bialas 1570 STK |
#32 | |
Liked 684 Times in 289 Posts
Mike A114 P/SA |
#33 |
I hope I'm not giving away secrets or making anyone mad by saying this:learn everything you can about qualifying to the 1000' line. Qualify as slow as you can then pick it up if you need to. With a decent log you can extrapolate enough to dial in to the quarter from your 1000' data. It took me a couple of years to start doing this but as the owner/builder/driver of a .6 under C/SA car I can assure you that it made all the difference. Your experience will be different with a rare stick car I'm sure but every race I go to has at least one car that can "eat my lunch" heads up and you better believe they're gunning for me! I'm just a guy on a budget trying to have fun with my old Max Wedge and it's really all good when I'm racing but I need every advantage I can think of that doesn't cost a bunch more money. Finish your car and come on in, the water's fine!
#34 |
Liked 2 Times in 2 Posts
I'm just impressed you used the word Extrapolate!
#35 |
Liked 780 Times in 194 Posts
"Extra-polate" Does that have to do with dentures?
#36 | |
Liked 535 Times in 86 Posts
#37 | |
The info you are seeking is not exactly a secret. I am curious as to how you are going to use a 5-speed. I assume the one it comes with?
#38 |
Liked 3 Times in 2 Posts
I have been looking at several options for 5 speeds. There are a few good OEM Ford units available, like the T5 with Liberty gears and internals, G-Force also does a well built OEM T-5, then there is also the TREMEC series of trans were availalbe in many Mustang GT's.
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
#39 | |
Liked 372 Times in 130 Posts
^^ This
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
#40 | |
A beefed up T5 or T45 with a modulaqr blowproof bellhousing might work. Astro Performance can build one. Hanlon Motorsports can build one with Liberty internals. Up until this year, there were a lot of Coyote Stock racers in the NMRA using a beefed T5 behind a 5.0 Coyote modular crate engine running mid 10's. If you go with a 2002-2004 Tremec 3650 that came in the Mustang GT those years it will require a Hanlon Motorsports adater to fit it to a sfi bellhousing like the Quicktime bellhousing.
