Old 11-23-2016, 12:47 PM   #31
Carguy49
Liked 2,967 Times in 713 Posts
Default Re: Tru start poll Division 6
the poll - yes.
Ron McDowell - Did Race
Old 11-23-2016, 12:58 PM   #32
Mickey Whaley
the poll - yes.
So how will this reflect the other divisions ? without taking their own vote?
Last edited by Mickey Whaley; 11-23-2016 at 01:01 PM. Reason: because i wanted toooooooo
Mickey Whaley is offline   Reply With Quote
Old 11-23-2016, 02:06 PM   #33
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Thanks for explaining Peter. That is exactly the way I thought it worked and see no down side to it. Unfortunately many stories get embellished as time goes on confusing the true intent.
Rich Taylor
I/SA - 321
Old 11-23-2016, 02:46 PM   #34
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Peter: Thank you. When I get my car converted, I'm in.
Would the RTs on the scoreboard read
LEFT -0.002 WINNER
RIGHT -0.018
Micky: James is seeking opinions of D6 drivers affected by this. James and Jim Storms run the Stock/SuperStock Combo series out here.
Dale Shearon
68 Mustang 6394
Old 11-23-2016, 02:58 PM   #35
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
LEFT -0.002 WINNER
RIGHT -0.018
Why would there be RTs on the scoreboard in an elimination round?
S/ST 51
S/C 53
Old 11-23-2016, 03:14 PM   #36
Greg Marshall
Greg Marshall's Avatar
Liked 10 Times in 6 Posts
For Tru-Start
since the car that breaks out the most loses,a similar rule should apply on the starting line .
Greg Marshall is offline   Reply With Quote
Old 11-23-2016, 03:20 PM   #37
In a heads up race, the worst red light is also the first & losing, right? Same as a handicap pairing now. Am I missing something?
Yes, I believe so, Ed
In eliminations , when a heads up run occurs, the computer sees a different segment (for lack of the proper term) of the program.. Index, instead of dial-ins, no breakout in effect. I assume when in that mode, it won't see T-S at all.
However, in the case of different class, same exact dial in.... Let's say 1st car leaves early with a -.002, and then the 2nd car leaves 2 tenths later, obviously green, the 1st car's red light won't come on until the second car leaves the beam.
Correct me if I'm wrong, Peter.
Really ,this is all you need to know:
The Worst Red Light Loses... Period.
Old 11-23-2016, 03:20 PM   #38
FireSale
FireSale's Avatar
If TruStart determines a winner, it should show on the scoreboard and how. We have very good anouncers but some of them speak gibberish.
I ran bracket at the tracks that James and Jim run the Combo. I always saw my dial change to my RT on green (or red). I think it flips back to my dial after that, but I'm generally busy with stuff at the time. CJ in the rearview and such...
I don't want to get off topic, but one of the things about modern drag racing that confuses new people is a lack of winner info from the scoreboard. On a breakout it gives dials and ET, but not the math that determines how the second car to the line won. If it flashed 10.30 / 10.28 / -0.02 all the info would be up for the fans. Might help with announcer code "Stevens dead on 9 ! Johnson breaks out by a thou !"
Scuse me. I'm a data junky.
Dale Shearon
68 Mustang 6394
Old 11-23-2016, 03:29 PM   #39
Peter Biondo
Sponsor
Peter Biondo's Avatar
Liked 5 Times in 3 Posts
Dale-
The scoreboards will function exactly as they do now. The only difference is with TruSTART the appropriate win-light wouldn't be on until both drivers leave the starting line.
The way it is without TruSTART (currently), the race is automatically (instantly) over when the slower car leaves with a foul start. With TruSTART, the timing system waits for the faster car to leave the starting line, and at that point it determines the winner and turns on the appropriate win-light in a red light (or double redlight) situation.
Hope this helps.
Peter Biondo S/Pro 1136 SS1136 Stock 1136
Biondo Racing Products
Peter Biondo is offline   Reply With Quote
Old 11-23-2016, 03:44 PM   #40
FireSale
FireSale's Avatar
Double red heads up
right -0.010 W
left -0.012 L
Double red handicap (current)
right leaves first -0.010 L
left leaves second -0.012 W
Double red handicap (TruStart)
right leaves first -0.010 W
left leaves second -0.012 L
Handicap becomes as fair as heads up.
Dale Shearon
68 Mustang 6394
