Old 11-11-2016, 10:43 AM   #1
Dave Ficacci
Dave Ficacci's Avatar
Liked 98 Times in 23 Posts
Default 1970 Nova - Super Street - Super Pro ET
10.90 @ 143 mph in Super Street trim
Pro Motion built 440 SB Chevy - Built 2016 - 800 HP – Have Dyno Sheets
Iron Eagle Block with raised cam tunnel
Comp Cams .840 lift
Callie crank and rods
Brodix 245 spread port heads - T1 valve spacing
TD offset rockers
Manton Tool Steel push rods
SRP coated Gas Ported Pistons
Belt drive
Vacuum pump
Stefs custom oil pan
Brand new Hedman 2" to 3 1/3 coated headers
Select Performance Power glide with Reid Case. Fresh 2016
Select Converter – Fresh 2016
Products Engineering fuel system bypass regular – New 2016
Mega 450 Digital Delay Box
# 1 Throttle Stop,
MSD 7AL3
MSD HVC 2 Coil
MDS Distributor
Moroso Ultra 40 Wires
Painless Wiring
Dana 60 with 4.88
Ladder bar
Strange Disc brakes front and back,
QA1 coil overs all around
Tubular front arms,
5 passes on brand new rear Hoosier rears
Certified 8.50 cage
New Simpson belts
Optima Batteries
Very consistent and dead straight every time.
Won Super Street Championship in D1 2014.
Jegs Allstar 2015
Complete Turnkey car ready to go racing today.
Comes with half drum M5 alcohol, Brand new spare starter, spare MSD Ignition box, two spare Strange calipers and brake pads, gasket set and 4.56 gear set.
All fresh beginning of this season Only raced it four times this 2016 season.
$25,000.
Frank Quarno
fquarno@hotmail.com
973-390-3422
Dave Ficacci
1013 STK
1170 SS
Dave Ficacci is offline   Reply With Quote
