Old 11-05-2016, 06:19 PM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default 350 Block ID
350 4-bolt main. Casting #3970010. Deck stampings V0830TDR. Under timing cover it has 020. Havn't seen it in person but it's for sale at a machine shop. 1971 casting?
brian schuetta is offline   Reply With Quote
Old 11-05-2016, 07:21 PM   #2
Dennis P Chapman
Liked 53 Times in 25 Posts
Default Re: 350 Block ID
68 to 79 4 bolt main high performance and truck use by my book
Dennis P Chapman 1904 STK
Old 11-05-2016, 09:14 PM   #3
brian schuetta
Anybody guess at the value of a block like this? Ten years ago I would give $100 to maybe $200 for a 010, 020 block.
Old 11-06-2016, 09:54 AM   #4
carl hinkson
Liked 18 Times in 10 Posts
If it has the 2482 center caps those are the nodular iron caps GM used on heavy duty engines which would be a plus.
Have it sonic tested before you purchase to make sure you have a good foundation to start with.
carl hinkson is offline   Reply With Quote
Old 11-06-2016, 09:58 AM   #5
About that much.
Hard core racers buy aftermarket because it's cheaper and more certain.
A lot of the rest buy crate engines.
Old 11-06-2016, 10:30 AM   #6
Greg Reimer 7376
Liked 718 Times in 220 Posts
Question Re: 350 Block ID
That 010-020 block supposedly had a higher nickel count so it would hold up in a truck. Problem was, they tended to be rather thin in places and a lot of them had a lot of core shift. They were real common at one time, I bought a crashed but fixable 71 El Camino, 350, 2 barrel,put a crate motor and a front end on the El Camino, painted it, and drove it for several years.I tore the engine down, and even though it was a 2 barrel, it had an 010-020 2 bolt main block.It was the original engine out of that El Camino,the VIN was on the block.It passed a sonic test, we filled it and went .042" over with it. I raced it a long time like that. Any more, by the time you buy 4 or 5 cores or junkyard engines and pay to clean and sonic test them all, a Dart block new in the box from Jegs' or Summit is about the same price, so that's a better deal. If your block sonics good, use it if you can.
