Old 10-20-2016, 08:52 PM   #1
weedburner
Liked 20 Times in 16 Posts
Default Re: Launch RPM
About 500 less than you would expect from the ratio change.
weedburner is offline   Reply With Quote
Old 10-20-2016, 10:34 PM   #2
james schaechter
Liked 1,436 Times in 299 Posts
Typically, in a our stocker we see a 200-300 rpm spike of driveshaft rpm at each gear change.
James Schaechter 3163 STK
Old 10-21-2016, 01:49 AM   #3
weedburner
If the clutch is used on the shifts, there's little if any spike. Because the slipping is basically a hydraulically timed event that re-sets when the pedal is bounced off the stop, rpm loss after the shift occurs over an extended time period much like the launch. Rather than jerking rpm almost straight down until a PP with centrifugal can relax, the loss will look more diagonal on the graph. Because the car is gaining speed while the clutch is slipping, spreading rpm loss over more time reduces both it's quantity and intensity, making that returned energy more likely to do productive work rather than go up in a blip of wheelspin.
If you are clutchless it can still help you launch higher, but you will still need an adjustable/centrifugal to get some slip on the shifts.
Grant
Old 10-21-2016, 05:37 AM   #4
james schaechter
I went to your link. You have done some really cool and well done modifications there. I see how you get the radials to work as well. In our world, the tradeoff is not likely to benefit us, compared to what we are able to legally run, but I can see where it is better for your combo. Well done!
Old 10-21-2016, 08:53 AM   #5
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
x2!!!!! Very nice work, Grant. Definitely outside the box thinking. Super cool little car. Must be ridiculously fun.
Kevin
