Liked 33 Times in 16 Posts
Replaced the electric clock in the dash cluster with a voltmeter instead of hanging it off the bottom of the dash as you usually see...
Rich Taylor I/SA - 321 |
Thank goodness it's back home...it will never be out of my sight that long again I can assure you.
Painted -
Liked 799 Times in 236 Posts
Rich, that's a well thought out installation.
"That'll never work....." |
Liked 223 Times in 73 Posts
Very nice roll bar installation!
And I like the voltmeter, I have the stock (broken) clock there myself. |
Liked 2,951 Times in 709 Posts
Looks good. Very cool that you accomplished your goal.
Ron McDowell - Did Race Every day is a Gift - Enjoy with family and friends. |
Those station wagon rear seat footwells work for more then just hidden storage. Good deal. Much better then through the window. IMHO.
Harry6674 |
Worked Friday and today getting the headliner and glass installed (a first for me).
![]() ![]() ![]() ![]() ![]() Late this afternoon after finishing the glass I decided to lower the engine into place to see if I had a set of headers on hand that would work for me. It soon became apparent something was wrong...I could not get the motor mount bolts in/aligned to save my life. I have had the engine in the truck many times and could easily drop it in by myself with zero difficulties. After about an hour of cussing and head scratching I spied something else I had not noticed since it returned home from the roll bar installation...the truck was leaning towards the driver side quiet a bit. Measurements revealed the driver side of the truck is about 3/4" lower than the passenger side. I can only guess at this point the welding/install of the roll bar has somehow caused this. I was able to loosen the engine frame mounts to finally get the motor mount bolts in, but that is a bandaide that does not address the real problem as it still has the lean. Not sure what to do at this point, but I know I won't satisfied with a vehicle heaved over to one side. ![]() ![]()
