Liked 11 Times in 4 Posts
thanks mark
larry dowty 6388 SS |
Liked 129 Times in 59 Posts
You still need to be among the 128 quickest qualifiers (or an alternate) to make the show.
Lew Silverman #2070 "The Wagon Master" N/SA |
Several years ago Larry (prior to 200?), if you won class you'd get in, and the remaining spots would be filled with the quickest non-class winning entries. However, several racers (faster classed?), complained to NHRA about their running further under their index than many of the class winners, and NHRA gave into them. There was a thread about this sometime ago (last decade too?), and it may have shed more light on who benefited from that happening, and why it happened....
Gary Hampton '86 Z24,173 V6 CF/S #5824 (#78 in 2021) Last edited by GarysZ24; 10-07-2016 at 10:25 PM. Reason: I spelled there wrong... |
#4 | |
Liked 7,937 Times in 1,518 Posts
I've raced a Sedan Delivery , many coupes , and a ragtop but none drove as well as my 'friggin red Camaro"........... Get over it .
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
#7 | |
Liked 1,821 Times in 413 Posts
Yeah, but back then "that class advantage" meant over the cars in your individual class, to be the fastest car in your class, and not to be the fastest car in your class because you're the only car in your class. Big difference.
Alan Roehrich 212A G/S |
#8 | |
Liked 326 Times in 78 Posts
Liked 317 Times in 103 Posts
Hey Jack Flash, your friggin red Camaro should drive better than all your previous cars. With all the technology in your friggin red Camaro and the price tag that goes with it, it BETTER be the best. The manufacturers put you into a position to run as fast as you do with their advertised horse power ratings. By the time the AHFS sorts you all out, the newer breed of friggin red Camaro's will be out making your car another also ran.
The only benefit of being the fastest in your class is bragging rights. Class means nothing anymore. Just the fastest "rated" cars are in. Look at the qualifying sheet, it is dominated with newer cars in the upper half. Of course except for combinations that NHRA graciously re-rates and then is in the top three. Ooops, how did that happen. So Larry, there you have it, winning class is for ego, not qualifying. Ron Ortiz U/SA my wagon is gray and friggin red.
Ron Ortiz 2102 STK |
Liked 32 Times in 19 Posts
Whether you won class because of the NEW cars with underrated factors or overlooked low class turbo vans is the same thing. You are an artificial winner courtesy of NHRA and its factoring methods.
Find a class of all the same car and you deserve to be proud of "winning class" regardless if all of you are underfactored the same. The mod SS classes could be better if the attraction of the New car factoring weren't available. |
