#11 |
Liked 372 Times in 129 Posts
Thanks!
#12 |
Liked 397 Times in 156 Posts
Just throwing this out there...I see you're testing at 600rpm per sec (which is standard) did you (or would you consider) dynoing at 300rpm/sec? The reason I ask is it has a heavy rotating assembly and a super steep gear might actually slow it down as too much torque wasted spinning up the heavy internals?
Like I said, just throwing it out there....food for thought as it were. |
#13 | |
#14 |
Liked 7 Times in 5 Posts
In stock your not suppose to be able to do anything to the heads and intake besides a valve job right? although judging from your other post and that you seem to have a in house dyno and who knows what other equipment your probably perfectly capable of altering that to your advantage.
#15 |
Liked 109 Times in 44 Posts
Jason Line 70 Buick Gran Sort 10:45 in C/SA at Indy this week!
Scott McIntyre-Cornville-retirement at last! 2015 Chevy SS. LS3/ 6 spd Stick-Wolf in sheeps clothing! |
#16 |
Liked 184 Times in 113 Posts
#17 | |
Different valve angles and seat width effect flow, and that's just as two examples of what he meant by "work on the heads". There are many more legal things to do before resorting to "port the heads and cover it up" as you're insinuating. Uncalled for imho, there are a lot of people with a lot of equipment, doesn't mean they must be cheating because they have fancy tools. |
#18 | |
#19 | |
#20 |
Liked 10 Times in 7 Posts
Just wondering where you got the car? I ran the same combo in the past I have a good set of 71 heads TA SS valves with Poston springs off the car along with a few other parts. I am located in Texas now formally Va.
