Old 08-10-2016, 06:00 PM   #1
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Default Re: Onan 7.5DKDFJ Generator Fuel Shut Off Solenoid
Pete I looked in the print for your machine and the pull coil B+ comes from a relay. Not sure if it is on a board or seperate. Just track that aux. terminal wire back to it's source. Probably not as easy as it sounds but that is what you have to do. That is assuming the solinoid test we talked about on the phone proved the solinoid itself was moving once you externally powered the aux terminal....
Rich Biebel
S/C 1479
Stock 147R
