#91 |
Liked 719 Times in 220 Posts
I've got 3 2 bolt main 396 blocks out in my store room. I'll look at and write down the numbers and we'll ID what they are. You got me curious.Isn't there a grooved rear cam bearing available to enable the use of the later cam in the early block? I know that a 409 has a grooved rear journal on the camshaft itself.That must be where they got that from on the early 396.
#92 |
Two of the three blocks are # 3855961. Both have fully grooved rear cam bearings.The other block is #3969854. It has also a later screw on oil filter,the other two have canister type filters.
#93 |
Liked 799 Times in 236 Posts
3855961 blocks are '65-'66 396. Interestingly, some '66 427's also had this casting
number. 3969854 is a '69 396 and was also used in the '70-'72 402's.
"That'll never work....." |
#94 |
Liked 782 Times in 195 Posts
In my records, I have recorded three 961 2-bolt blocks that sonic checked over .250" thick cylinder walls.
#95 |
I remember reading about the 396 375 horse 4 bolt main block being "dual purpose,"that meant, 396 or 427. It had some massively thick walls, in one case, one was bored out to 4.3150 and used a standard 409 ring. Imagine a 440 inch 396 coming at you! The later block I have was a 70 402. It had 290 small plug heads, the flat intake, and a cast crank.
#96 |
I don't have much good to say about the later blocks.
#97 |
Liked 53 Times in 16 Posts
Been a long time coming, near the finish line. Over 3 years now, best I can do on a limited budget. 396 Shortblock done, finish heads. Then driveshaft has to be made.
Plan is August Will Lamprecht Div 1 I/SA 65 Impala 396/325 |
#98 |
Liked 18 Times in 12 Posts
WOW!
The car looks AWESOME ! I love it .
"Real Race Cars Have Tailgates" |
#99 |
Liked 223 Times in 73 Posts
Looks fantastic!
#100 |
Liked 520 Times in 132 Posts
That car is awesome!
