Old 07-24-2016, 09:18 PM   #1
Woodfin
Liked 288 Times in 109 Posts
Default lathe choices
With the outfitting of my retirement/hobby shop I will be adding a medium size lathe.
Let me hear what some of you have
Old 07-24-2016, 10:22 PM   #2
SSGT Mustang
Liked 204 Times in 54 Posts
Default Re: lathe choices
I have an old south bend heavy 10. I love it and use it often.
Tooling will kill you if have to buy everything new. Most people don't need a taper attachment. However, you should get a good 3-jaw chuck (with inner and outer jaws) and a 4-jaw. Aloris-type tool holders are a must. And you should get a Starrett level to set up the machine.
The ways are critical. Buy a good used machine, but don't settle for crappy ways. Check the run out on the bed and the tail stock alignment before buying. If the runout cannot be corrected within reason, then pass on the machine.
Check out this guy on youtube. Lots of incredibly valuable information. Enjoy.
https://www.youtube.com/user/mrpete222
SSGT Mustang is offline   Reply With Quote
Old 07-25-2016, 12:16 AM   #3
older racer
Liked 68 Times in 26 Posts
hi, I have a jet 13x 36 . its good quality and works great. a bit bigger might be better, esp if you get a gap bed lathe. lots of sizes out there. good luck.
older racer is offline   Reply With Quote
Old 07-25-2016, 12:55 AM   #4
I would look for an older Ohio type lathe. A Sydney or a Leblond. You can still adapt the import stuff to them like a 3 jaw Chuck. I would look for a long bed with an 8-inch swing anyway. The import tool bits aren't too bad from MSC Supply for occasional hobby type work. If you find one that's three phase and you don't want that you can just put a 220 motor on it. You just won't be able to reverse it in case you're into cutting reverse threads or something.
Old 07-25-2016, 09:34 AM   #5
Liked 10,762 Times in 2,237 Posts
A good source for a used lathe without a lot of use is the school systems or a tool room lathe from a company going overseas. Also make sure it will cut inch/metric threads.
Old 07-25-2016, 09:52 AM   #6
tj310
I suggest Practical Machinist website as a good source of info and used machines ...Trevor
Old 07-25-2016, 09:55 PM   #7
Jeff Teuton
Liked 325 Times in 50 Posts
I'm not sure what you are looking for, but since I combined my machine shop and race shop, I got some duplicates. email me and let me know. jefft@southlanddodge.com. I have a medium lathe, an old Bridgeport, and I'm not sure what else you might need.
Jeff Teuton 4022 STK
Old 07-25-2016, 11:40 PM   #8
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
I can tell you, without a doubt, please do not waste your time with "new" Chinese-made lathes. Resist the temptation to purchase a nice new shiny, pretty painted machine from the multitude of Communist machine peddling companies. The build quality and inability to hold tight tolerances, or make heavy cuts without slop-induced chatter on these machines is well documented... Don't be a sucker... The grizzly chews on wood just fine, but he's not at all up to the task of chewing on steel........
Do you want a hobby lathe to make neat little parts for Radio Control airplanes and cars, or do you want/need a machine to make real parts for real machines? I have both, and indeed, they both have their place.
But before you decide, make sure you know what you are really trying to produce, and how quickly and accurately you need to make it..... Sure you can hold a thou if you creep up on it for the last 10 thou, 1 thou at a time....
But a real machine will take '30 thou cuts, right to the the near end, then finish with a 1-2 thou cut, clean as can be (assuming the part itself isnt flexing).
Spend some time on used equipment sites, auctions, and private listings and find a real, non-third world-made machine, in good shape, and you will have no regrets.
Kevin
Old 07-26-2016, 01:26 AM   #9
Coleydog
Liked 53 Times in 38 Posts
I would like the Bridgeport but you just to far away, oh well
Old 07-26-2016, 08:33 AM   #10
Woodfin
Jeff, Thanks, I'll get with you at some point.
