Old 07-16-2016, 03:00 PM   #1
Dana Fitzpatrick
Liked 10 Times in 6 Posts
Default Power valve?
I've got a 68 Camaro stocker that currently has a 461 in it.I've always ran a primary pv in it when it had an automatic,it now has a stick,no changes to the engine.It's very choppy in 1st gear going thru the pits,clears up halfway thru the gear.Do you stick guys run power valves?
Dana Fitzpatrick is offline   Reply With Quote
Old 07-16-2016, 03:23 PM   #2
Dana Fitzpatrick
Default Re: Power valve?
Sorry,I meant to post this in tech.Will the moderator please move it? Thank you.
Old 07-16-2016, 03:31 PM   #3
BLIND MULE
BLIND MULE's Avatar
A power valve will help but you dont want it to rupture if you ever had a backfire! I never run them have had good luck without!
BLIND MULE is offline   Reply With Quote
Old 07-16-2016, 05:20 PM   #4
Dana Fitzpatrick
Just to be clear,it does have a pv in it now,same one that it had with automatic.
Old 07-16-2016, 07:08 PM   #5
Chevy55
Banned
Liked 179 Times in 89 Posts
Power valve is only affected by engine vacuum. and it must be closed at idle The # on the PV body is the inches of vacuum it will open.
Check the engine vacuum and use a PV a couple inches higher.
Think I got it right.
Chevy55 is offline   Reply With Quote
Old 07-16-2016, 08:24 PM   #6
BLIND MULE
BLIND MULE's Avatar
Maybe around a 3.5 PV just a guess?
Old 07-16-2016, 08:30 PM   #7
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I've been advised to do away with any PV...no more guess work.
Rich Taylor
I/SA - 321
Old 07-16-2016, 10:59 PM   #8
BLIND MULE
BLIND MULE's Avatar
I never run them my homemade carbs get the job done!
Old 07-17-2016, 10:51 AM   #9
Dana Fitzpatrick
Thanks everyone. Power valve is correct for engine,even tried a new one,cleaned out carb,blew it out,float level and fuel pressure checked.This carb worked very well with a foot braked auto,crisp and did not have the problem going thru the pits in 1st gear.Problem started with stick installation,it's choppy and surges until about 2500-3000 in first then is fine.I just wondered if the stick guys pulled the valve....I'm going to order a block off plug and up the jets......Thank you.
Old 07-17-2016, 11:42 AM   #10
Woodfin
Liked 288 Times in 109 Posts
I am watching this question with interest.
*one thought, when driving at low speed only have the throttle open a small amount and regulate the car speed by selecting whatever gear gives the desired pit road speed.
*I have experimented with power valves on gas carbs. I like the low speed performance and cleaner when staging with footbrake. With trans brake leaving where you are wide open on converter or two step I do not run a power valve.
*I do know it is common with Methanol carbs to run a primary power valve.
It may mostly come down to personal preference.
I would like to know the % of who runs what.
Woodfin is online now   Reply With Quote
