#21 | |
Liked 799 Times in 236 Posts
![]() The valley is much like a big block Chevy. They are a priority main oiling system, so the mains get oil first, then the cam/lifters....just the opposite of a factory small block. You can flood the top end pretty easily, so the lifters need to be chosen carefully.
"That'll never work....." |
#22 | |
Liked 33 Times in 16 Posts
Rich Taylor I/SA - 321 |
#23 | |
Liked 18 Times in 10 Posts
Dart blocks do use priority oiling and they get the same oil up to the top as a stock block. Nothing is restricted on the block to decrease the flow of oil to the top end. Don't use the Dart cam bearings with 3 holes to much bleed off if you want to talk about oil running down on the cam. |
#24 | |
Liked 13 Times in 11 Posts
#25 |
Liked 4,377 Times in 502 Posts
I was getting oil in the intake. I'm going to try an oil separator and reconnect the pcv valve to the factory spot in the back of the manifold. So let me see if I understand this. At idle the gases are being sucked into the valve cover breather through the crankcase, out the pcv valve and back into the manifold. At full throttle the pcv check valve is closed and the valve cover breather is handling all evacuation of the crankcase?
