I sent this back last season and had it upgraded to 70-80 amp this is a one wire ultra mini
Kit 2414 Big Block Chevy with Front Motor Plate. This kit locates the alternator in front of the motor plate. Great for Super Gas and Street Cars Kit Includes : ◾2025 Alternator ◾2234 Bracket ◾2252 Pulley ◾2370 Wiring Kit ◾15265 Belt East Coast Auto Electric UltraMini 12 Volt Series MINI-ALTERNATOR The UltraMini Alternator is the smallest in our line. It weights only 6 Lbs. and has an output of 55 amps. When Mounted with our low mount brackets (2230 for BBC, 2231 for SBC) it will fit between 18 inch frame rails. When used with our 2232 (BBC) or 2233 (SBC) mid mount bracket, it will fit most stock chassis that do not have a motor plate. It is avaiable as a one wire or an ignition activated unit so it can be switched off http://ecae.com/kits/2025bbcmotorplate-2.jpg East Coast Auto Electric UltraMini 12 Volt Series MINI-ALTERNATOR Kit price @ 55amp $ 440.94 I had it mounted on left then right side it worked either I will sell upgraded kit for $300 + ship (no wiring kit inc) 410-713-0071
KEITH MAYERS 2-1/2 X somebody Still many X nobody Last edited by Keith 944; 06-14-2016 at 09:42 AM. Reason: add info |
