Liked 223 Times in 73 Posts
Yeah, I wish it was only 100 degrees!
I hope that stuff helps some, Rob. And thanks for not looking too critically at the paint! I still have to re-do a few small areas on the paint tomorrow, then I'll break to head out to Wild Horse with the Camaro. On Sunday I hope to apply the polymer sealer and start putting on the moldings and emblems. |
Progress is really slow at this point. Mostly my accomplishments in the garage are inversely proportional to the temperature.
I did manage to do another round of sanding and buffing, and now waxing the paint as well. So having that completed now I'm adding emblems and moldings. The trunk also opens via the key now, although that wound up being more of an adventure than it should have. Seems like nothing fits easily on this car. This Sunday I tried installing the front bumper. I was having some trouble getting things to line up (of course!) but the thermometer had no trouble at all getting to 114 degrees about the time I gave up. I must confess I could also sense All Access calling me! Now that I know how to get that on the wife's Roku I can see that nothing is going to get done around here on Labor Day weekend! Anyway I'll try again this coming weekend. I may have to do some hacksaw and welder work on the brackets to make up for earlier damage from a mild collision. ![]() Last edited by Dave Muller; 07-08-2017 at 01:11 PM. |
Liked 251 Times in 125 Posts
Don't beat yourself up, Dave. I am pretty sure that most people would not see any progress in the kind of heat that has been out your way lately.
"It's not just a hobby, it's an adventure!" |
Liked 520 Times in 132 Posts
Great build. I really like that year.
Thanks, guys. The encouragement helps keep me going forward.
I'm sure slow progress will be the theme for the next couple of months.
This weekend I got the rear bumper installed. That was easier than the front. I only had to cut, bend and re-weld one cross brace. The front brackets, I decided, just weren't worth the trouble. They are twisted and pushed almost an inch to the left side. I ordered new ones. The taillight bezels are only in here for a test fitting. I have to remove the corner pieces to get access to their mounting screws. But I did also get the trunk weatherstrip installed. ![]() The challenge with those taillight bezels is they use weird captured nuts that, as far as I can tell, are only available if I buy new bezels. But I think I can fabricate some using sheet metal, tin snips, a drill and self-tapping screws. I do have two of the eight nuts so I have an idea what they're supposed to be like. Meanwhile I found that I have three door handles. Unfortunately only one fit properly, the other two have much longer actuating rods. It does seem like the one that I need will fit after cutting the rod down. I ordered the rubber gaskets for those, they should go in when those and the bumper brackets come in. I'm hoping by the holiday weekend, but probably not. Restoration suppliers aren't all that fast. Last edited by Dave Muller; 07-08-2017 at 01:13 PM. |
#7 | |
Liked 13 Times in 7 Posts
But it's looking real good Dave, just keep hammering away at it a little at a time. It will get there. Behind you all the way!
Brian Saunders Lerna IL '79 AMX T/SA 3790 currently being resurrected |
Thanks, Pinballer.
I am very fortunate to live just two miles from Space Age Paint, where they have all sorts of specialized hardware for old cars. They didn't have the nuts I needed to mount the taillight bezels, but they did have others that were usable after applying pliers and tin snips. So now the rear trim and taillights are done. ![]() Last edited by Dave Muller; 07-08-2017 at 01:14 PM. |
