Old 06-09-2016, 01:24 PM   #11
colormebad
colormebad's Avatar
Default Re: Timing retarding 2* after installing crank trigger
Originally Posted by pmrphil View Post
The timing chain has nothing to do with timing when using a crank trigger, only affects the position of the rotor. I just adjusted for it so it was correct at RPM. Sure does make you wonder, huh?
That's what 2 MSD techs told me... Its hard for me to 100% believe but I will find out one way or another... Its down to this bracket needing to be bolted to the motor instead of the motor plate, and with a new bracket, or the balancer...
colormebad is offline   Reply With Quote
