Old 05-31-2016, 12:30 AM   #31
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: 350/255HP Help please
Originally Posted by Alan Roehrich View Post
Agreed. Cold leak down is useless. Honestly, on these engines, you need to be using a Dwyer gauge, or something, to test blow by on the dyno. Leakdown, even hot, can be misleading. Measuring blow by eliminates all of that.
Alan, could you describe how the Dwyer gauge works?Is it basically installed like a vacuum gauge? I've never heard of one.Looks like there are several different calibrations.Which is correct to use to measure ring seal as you described? Thanks,Mark
Old 05-31-2016, 01:18 AM   #32
Liked 1,880 Times in 422 Posts
Mark, if memory serves correct, you want one that reads 0-10 scfm. The 12" tall model is probably the best.
What you do is connect the gauge to the only outlet where any crankcase pressure can escape from the engine, everything else must be completely sealed. The easiest way is to connect the gauge to a breather with a tube outlet, such as the one used in a crank case evac kit. The gauge must be mounted perfectly vertical.
You then make dyno pulls as you normally would. We normally use our vacuum and or evac system for a while to seal the engine up, then after we've got it where we want it and tuned, we make a couple of pulls with the Dwyer gauge on it to make sure it is sealed up.
Old 05-31-2016, 10:44 AM   #33
V M Kauffman
The one I used was a Fisher-Porter same one Chryser Race Group used was about $300.00 30 years ago. I could hook it up as Alan described and if it was bad enough the weight in tube would bounce just spinning on starter. We would check engine every time we loaded car to come home by hooking up meter and just free rev engine to 6500 rpm if Blowby was over 2 cfm engine would come apart we we got home. Difference on a 740 hp engine on dyno at 6 cfm down was down 60 hp to 1 1/2 cfm. Ted Flack showed us how to use it.
V M Kauffman is offline   Reply With Quote
Old 05-31-2016, 12:18 PM   #34
Mark Ugrich
OK , I get it now.All I could find online the other day was a round gauge with a bunch of NPT fittings and hoses stickin' out of it.Thanks Guys!
Old 06-01-2016, 07:20 PM   #35
Kevin Panzino
Kevin Panzino's Avatar
Liked 759 Times in 139 Posts
Look at a Dwyer Model# RMC-121. 1 to 10 Cfm range, 10" tall, 1/2" fittings.
Old 06-01-2016, 09:45 PM   #36
henrys57wagon
henrys57wagon's Avatar
What I don't know about building engines seems to outspace what I know.
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 06-02-2016, 09:57 AM   #37
GTOMayhem
Liked 22 Times in 14 Posts
Same here. I have learned so much in two years of lurking on ClassRacer.
Rick Thomason
GTOMayhem
GTOMayhem is online now   Reply With Quote
Old 06-02-2016, 09:54 PM   #38
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Finally got time to do a hot leak down. All cylinders are 5-6% both at tdc and approximately halfway down, at 150 degrees. No access to a dwyer guage here to check that.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 06-03-2016, 08:14 AM   #39
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Rick Thomason
GTOMayhem
Great testimony! Lurk on!
Old 06-05-2016, 07:13 AM   #40
GTOMayhem
What would the fix be after you tore it down? I know, probably a novice question. Also how would a supercharged engine change what you would be looking for as far as ring seal and blowby?
Rick Thomason
GTOMayhem
