Liked 760 Times in 140 Posts
Are you saying the leakdown is 8 to 9%????
Liked 239 Times in 90 Posts
Not trying to be ugly but that combo should make north of 430. How "new" are pistons? Most likely the problem is the ring package. Having said that I am not an engine builder nor do I build my own motors but I have been around stock for all my life and fairly up to date with what it takes to make them run.
#3 | |
Liked 373 Times in 129 Posts
Liked 1,892 Times in 423 Posts
You're down 35HP or more, and your peak is maybe 600RPM or more low.
If you're really leaking close to 10% on an engine that is up to 160 degrees, you're not sealed up. I seriously doubt that either Total Seal or CP has missed the mark on the rings or pistons, especially if you had them work together. I've used their stuff successfully many times.
Alan Roehrich 212A G/S |
Liked 880 Times in 311 Posts
He said "Cold" Leak. That never has told me anything. I don't race Cold Engines... Could have bad ex seats and when it gets hot they go away..... Just Saying...
Adger Smith (Former SS) Last edited by Adger Smith; 05-29-2016 at 10:17 PM. Reason: sp |
Agreed. Cold leak down is useless. Honestly, on these engines, you need to be using a Dwyer gauge, or something, to test blow by on the dyno. Leakdown, even hot, can be misleading. Measuring blow by eliminates all of that.
Liked 99 Times in 49 Posts
If its a junkyard block 384 is not that bad,if its leaking more than 6% you got problems, Call Greg at race rings get his ringpack give him the grove dept,and he will fix you up get it honed with a plate . Cam should be in at 103-104 with a three speed.spring pressure around 145 -385 with reg lifters. Bowtie should pick you up 20. good luck.Not all dynos are the same.
Liked 166 Times in 71 Posts
I'll get it up to temperature and do another leakdown. Don't have access to a Dwyer guage. Cam is in at 103. What you guys are saying about 35-40 and 600rpm down is exactly what I have been figuring but can't find why. Engine is a factory block but fresh at .065 with plate. Pistons are a couple years old, Manley rods, (light piston heavy Rod)
Chris Chapman 1969 Chevelle NHRA F-G/SA 1090 |
#9 | |
Liked 71 Times in 38 Posts
Alan, could you describe how the Dwyer gauge works?Is it basically installed like a vacuum gauge? I've never heard of one.Looks like there are several different calibrations.Which is correct to use to measure ring seal as you described? Thanks,Mark |
#10 | |
What you do is connect the gauge to the only outlet where any crankcase pressure can escape from the engine, everything else must be completely sealed. The easiest way is to connect the gauge to a breather with a tube outlet, such as the one used in a crank case evac kit. The gauge must be mounted perfectly vertical. You then make dyno pulls as you normally would. We normally use our vacuum and or evac system for a while to seal the engine up, then after we've got it where we want it and tuned, we make a couple of pulls with the Dwyer gauge on it to make sure it is sealed up.
