Liked 130 Times in 20 Posts
For Sale:
Jerico 4 speed DR4 top and bottom loader transmission- Long pistol grip shiftier with stops and line loc button. Chrysler 1 3/16 18 spline input for GM stock depth bell housing 25 runs since taking apart, checking everything and replacing what was needed. 3.19 / 2.00 / 1.39 / 1:1 Trans was run in our H stocker the last year. $2,800 Parsons and Myers built 327 Super Stock engine. Can be run with 4gc carburetor as 1965 250hp engine, with a Holley as a 67 300 hp engine or with the Quadrajet carb as 1966 275 hp engine. Quick Fuel 585 carburetor HVH super sucker 2" carb spacer Edelbrock intake by Heads Up Heads up heads (1 new head this past winter) Jesel shaft rockers Manley Valves Sheet metal valve covers 7/16 tapered push rods PAC valve springs Bowtie block .937 Jesel keyway lifters 50mm Roller cam bearings Comp Cams camshaft Jesel belt drive Diamond pistons Total seal piston rings Manley rods Honda journal Bullet cams built lightweight crankshaft Mallory front drive distributor ATI Balancer Aluminum kick out oil pan This engine is built with the best parts, is very reliable and went -.91 under (9.589 @ 136.98 in GT/E) in Charlotte at the points meet rd1 50 lbs heavy with regular oil. $15,900 Engine and trans will be at the sports nats in Bowling Green this weekend. Call text or email for more information. Thanks Brad (616)437-4958 brad@zaskowskibuilders.com
Brad Zaskowski 3697 STK, SS |
Liked 6 Times in 3 Posts
Hello Brad , I'm still Looking for another engine , I've found a 305 engine trying to work a deal on it , are you firm on your price ? Can you tell me the bore of your block and how many runs on the crank and rods ? Thanks Jeff
