Liked 171 Times in 51 Posts
Got a little more stuff done this week.
Built a battery tray out of 1/8 aluminum in my welding class, put a little lip on it and some tabs to mount it to the body. Weighs a little more than the OE tray but it's much stronger. Turned out pretty good. I've been scraping undercoating and seam sealer out of the rear fenderwells for a couple days now. Nasty job at best. Using a Bernzomatic to soften it up, then scraping with a putty knife. After I get most of it off I go over it with a stainless steel wire brush on my angle grinder. I think the issue with the rear tire clearance will be resolved once I get the fenderwell lips folded up and add at least one inch clearance at the front and back of the wheel wells, as per the rule book you can go up to 2 inches. Finally got the rear brake lines installed. I followed the old rear brake line which routes through the firewall of the passenger side of the car, down along the door sill then across to the driver’s side under the rear seat and exiting to the rear axle. I'm not sure I like the new (new to me anyway) brake lines made out of copper/nickel. It's easy to bend but it looks like it may be easy to dent and therefore pinch off. |
Liked 69 Times in 30 Posts
Eastwood makes a great tool to fold the inner rear fender lip, you could make the tool in your welding class.lol Nice project keep it up.CR
Liked 237 Times in 126 Posts
The guy I bought my Mustang off of had covered the floorboards with that stick-on foil sound deadener. I spent several days cooped up in my coupe with a torch and putty scraper, so I feel for you. Smelly, dirty stuff. And the metal under the passenger side was so rusted I had to cut it out and replace it.
Nice welding and fabrication. Glad to see someone tackling all aspects of race car conversion themselves. I don't know what your paint plans are, but since I was going to strip and paint my car I used a torch and body hammer to roll my fender lips. That Eastwood tool is nice, but I already had the torch and hammer. Worked out OK. And don't believe those YouTube guys who say you can do it with a baseball bat... Dale
Dale[/QUOTE] Baseball bats on wheel wells are for the circle track crowd, in my opinion. I discussed this with my body guy yesterday, he is going to split the lip on the inside and fold it in. Should be about 1/4 to 3/8 thick when done. Car is going to body and paint Wednesday. Front fenders, trunck lid, hood and bumpers are already done. They look great. I found a one in a million with this guy. He works out of a single car garage, charges $20.00 an hour for body work and $35.00 for painting. I bought all the materials so he doesn't make any money on that. Is reasonably fast, gives me a bill every Thusday for work done the previous week. I inspect the work, if im not happy I don't pay until its corrected. No money up front. I'm pretty happy so far. |
#5 | |
Liked 780 Times in 194 Posts
Any possibility we could clone him???
Liked 19 Times in 12 Posts
Cool build. Good luck with it. Subscribing.
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
Finished getting the shifter installed on the trans. Looks cool and works like a charm on the bench.
The rest of the car went to body and paint, got the bumpers back. I wanted the bumpers to be silver originally but the painter being the creative type talked me into a candy blue over a silver base. I like the way they turned out. Car is Wimbledon White over dark blue on the lower body line. You can see in the picture of the fender. Now I have several weeks of nothing to do while I wait for the car to come back. Never mind I have plenty to do. Last edited by Shadylane; 05-22-2016 at 08:08 PM. |
Liked 43 Times in 10 Posts
With a little imagination, and that blue and white...you could turn back the clock to 1978 and think you were in Whiteland, Indiana.
Liked 223 Times in 73 Posts
