Old 05-12-2016, 10:25 AM   #1
fairlanedragracer
fairlanedragracer's Avatar
Default Reher & Morrison Big Block Chevy 509 takeout assembly
Complete Reher & Morrison 509 Big Block Chevy Takeout rotating assembly, Scat 4340, 4.000 stroke Crankshaft, Manley h-beams rods with ARP 2000 rod bolts, Ross pistons, 14 to 1 compression, .043,1/16,3/16 total seal rings, customs Reher & Morrison solid roller camshaft, Isky roller lifters, Manley double roller timing chain and gears with torrington bearing, pac double valve spring for the camshaft, moroso oil pan and oil pump with welded pickup. call Dave at victory Racing Parts 734-762-7665
fairlanedragracer is offline   Reply With Quote
