Old 04-27-2016, 09:51 AM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: 12-Bolt Spool Bearing Pre-Load
Thomas,
my method that has proven to give excellent results;
I select a shim pack that provides the backlash number I want and those shims will GENTLY tap into place with a small hammer. Thus, very light preload. It does require several trial fits to sneak up on the combination.
And speaking of preload, I also use very light preload with the pinion bearings and install a solid spacer that adjust with a shim pack.
When the install is complete as I describe the complete assembly is very easy to turn and the car is very easy to push.
Larry Woodfin 471W
