Old 04-12-2016, 06:23 PM   #1
RJ Sledge
Liked 294 Times in 93 Posts
Default Re: Stock Eliminator Block Question
You can use any Ford Motor Company SB. My advice is to find a later model "roller" style block (plentiful and cheap) and fill it to the bottom of the water pump hole with concrete/grout. We use the high tensile strength cement grout and its as good, probably better than any thing out there and a bunch cheaper. Have to thank the late Kip Martin for that. I think I have a standard bore already filled if your interested and can deliver to Houston National event in 3 weeks. $500.00 ready to machine. We went with an SVO block because of the 3.400 stroke of the 363 CJ combo.
RJ
RJ Sledge is offline   Reply With Quote
Old 04-12-2016, 09:04 PM   #2
ShadowLands
ShadowLands's Avatar
Great! Thanks for the help, gentlemen. Owner has at least one Mexican block but I will see if he is interested in the filled block you have, RJ. I might get that one for myself if he isn't wanting to spring for it.
ShadowLands is offline   Reply With Quote
Old 04-12-2016, 09:18 PM   #3
ShadowLands
One other thing..........what engine is Marty Buth using for N & O/SA?
Nevermind.............found it.
Old 04-13-2016, 07:25 AM   #4
Kirk Morgan
Liked 81 Times in 45 Posts
The block RJ is talking about is .030 finished bore and comes with a Canton girdle with fasteners and windage tray.
Kirk
Kirk Morgan is offline   Reply With Quote
Old 04-14-2016, 09:31 PM   #5
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Marty uses a 4 cylinder turbo combo.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
