Old 03-25-2016, 08:37 PM   #1
cal
cal's Avatar
Liked 31 Times in 18 Posts
Send a message via AIM to cal
Default Trans Break issue
Hello All.
We pulled the motor and treans out of our S/ST Camaro last fall to freshen everything up.
As it turns out the Stock Case Power Glide bell was split about 3/4 of the way around.
So I bought a ATI Case and Bell. Had a local trans guy switch everything from the stock case trans, to the new ATI case.
Now the trans brake won't work, I have been told to pull out the rod and drill and tape it with a pan head screw.
I have been told I need to weld a tip on the end of the shaft.
I'm not a trans guy, what is all this about.
Is there a longer shaft that can be bought or do I really need to do 1 of the above fixes. is this common or just my dumb luck.
Slightly confused, how do I resolve this problem?
Cal
S/ST 1177
cal is offline   Reply With Quote
Old 03-26-2016, 12:33 AM   #2
Kevin Panzino
Kevin Panzino's Avatar
Liked 759 Times in 139 Posts
Default Re: Trans Break issue
Did your local trans guy know to drill the holes in the back of the case for the transbrake?
Kevin Panzino is online now   Reply With Quote
