Old 03-21-2016, 11:07 AM   #21
joespanova
Liked 13 Times in 11 Posts
Default Re: Oil starvation issues SBC HELP?
OK Carl.....thats why I'm asking here. I don't do it for a living.
Bleed off is a good point. I'll definetly look at the cam bearings , lifter bore clearance and rod side clearance. I can't change the side clearance without ordering new rods , which I'm not.
I will buy a good pan if ness.
Old 03-21-2016, 11:22 AM   #22
joespanova
BTW.No one has referenced an accumulator AT ALL.
Why not? In theory could work.
Old 03-21-2016, 11:34 AM   #23
carl hinkson
Liked 18 Times in 10 Posts
You might look at 10552C pump would be a better choice at that kind of RPM.
Side clearance is not a factor in bleed off, I have build piston guided rod engines with .115 side clearance and no issues.
Its bearing clearance which regulates the amount of oil bleeding out between the rods.
Jake Stelter engine won Drag week 2 years in a row had some issues and was correct with a pan and pump. He is on F/B and might be of some help.
http://www.dartheads.com/dartboard/s...light=pressure
Good luck only trying to help.
Carl
carl hinkson is offline   Reply With Quote
Old 03-21-2016, 11:37 AM   #24
Ed Wright
Ed Wright's Avatar
If you have everything else right,you should not need it for what you are doing. Read Mike Taylor's post.
Ed Wright 4156 SS/JA
Old 03-21-2016, 12:17 PM   #25
joespanova
Carl
I know you are............and I thank you all.
I'm using the 10552c right now.......I 'll look at the thread.
Old 03-21-2016, 12:19 PM   #26
joespanova
I did..I read em all........at this point I'm thinking what could I lose by adding one ( or not lose )
Old 03-21-2016, 01:14 PM   #27
joespanova
Ed , you may want to read this:
about an accumulator
http://rehermorrison.com/tech-talk-5...-engine-alive/
Old 03-21-2016, 01:18 PM   #28
pmrphil
Liked 348 Times in 152 Posts
It won't fix the problem, just mask it.
Did you check bearing clearance yourself, with a bore gauge, or plastigauge?
As mentioned, aluminum rods grow with heat (any) and the bearing clearance will grow with it.
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 03-21-2016, 01:56 PM   #29
joespanova
Bore gauge.........set to the rod journal.
I'll go .002 if it'll help at this freshen up
Old 03-21-2016, 02:14 PM   #30
carl hinkson
If your using a cheap bore gauge with rigid fingers your not going to get a correct clearance. Not to many guys can afford good bore gauges to check bearing clearances.
Here is a thread on different bore gauges.
http://www.performanceboats.com/gn7-...learances.html
