Old 02-21-2016, 02:10 PM   #1
Dave Muller
Dave Muller's Avatar
Liked 223 Times in 73 Posts
Default Re: '66 Malibu N/SA
Originally Posted by HP HUNTER View Post
Theres a new dyno testing facility coming to North Phoenix, you might want to consider some dyno testing.
Very likely I will down the road a bit. It's been in the back of my mind.
Dave Muller is offline   Reply With Quote
Old 02-26-2016, 01:10 AM   #2
Dave Muller
A big part of why I like projects like this is working through all the little design issues, even the trivial ones. Like mounting the line-loc solenoid.
I've always mounted them on the inner fender in the past, but this time there were a couple of happy little bolts by the master cylinders saying "Use us! Use us!"
So I did, starting out by making a template:
Then cutting it out from a 1/8" sheet of aluminum and drilling it:
Then I mounted the solenoid and bolted the plate in place.
Now all I have to do is bend the existing lines slightly and they should line up with the fittings that I'll be adding shortly. The only new line I need to fabricate is a short one to the solenoid inlet.
Old 02-26-2016, 02:00 AM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I may have to copy that idea on the El Camino Dave.
Rich Taylor
I/SA - 321
Old 02-26-2016, 08:12 AM   #4
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
X2
Old 02-26-2016, 08:51 AM   #5
Dave Gantz
Liked 251 Times in 125 Posts
I don't envy all of the work you're doing, but it looks great!
I have to ask, why power brakes?
Old 02-26-2016, 11:16 AM   #6
Dave Muller
Why power brakes?
#1 - because they're there already.
#2 - because I'm not sure I can hold the car on the line without a trans brake otherwise.
Both mostly because of #1 combined with the fact that I've already exceeded my budget and I haven't finished the rest of the project yet.
Old 02-28-2016, 12:18 AM   #7
stocker396
stocker396's Avatar
Liked 58 Times in 16 Posts
Dave you dont need power brakes to hold, just good ones. Mine holds at 4200 on a two step with manual brakes(mopar style cylinder).
Also for the record Dave's Car is NOT the car running at the Division 4 race in Baytown this weekend! MINE is! LOL
Dave your build has gotten alot of attention and I have been asked at least a dozen times "Is this the car from class racer?" "How did you finish it so fast!?"
Mine is Pictured below and they are VERY different. Thanks for understanding.
Overkill is Under-rated
stocker396 is offline   Reply With Quote
