#41 |
Liked 431 Times in 224 Posts
You could ask Don Keen for his opinion on TruSTART...
S/ST 51 S/C 53 |
#42 |
Liked 8,014 Times in 1,526 Posts
#43 |
Pretty much spot on according to the trends mapped out by Beard. Should be roughly 1-2%. The tree has dropped 104 times between those classes.
S/ST 51 S/C 53 |
#44 |
Liked 805 Times in 245 Posts
I don't really care whether the first or worst red light rule were to be put in place but the reality is that you can't look at current statistics to mean anything as the tree is not blinded. This is obviously skewing what actions are taken by the faster car. Seeing the red come on the other side of the tree would obviously affect how the faster driver reacts.
#45 |
Liked 24 Times in 13 Posts
Bingo....most of the time it would only matter in a heads up race or races that are get close to the same dial. In other instances the car leaving last will continue having an advantage. For example an A car racing a N car after seeing clearly the red light by the N car, instead of just going for it freebie style- will simply just dog it.
Mike Keener A/S B/S C/SM |
#46 | |
I think the previous poster was pointing out that the current statistics of potentially impacted races are skewed because the faster car sees the red and then hits the tree harder as a result. It is a fair point, but I could imagine that there are also drivers who become by distracted by the red and don't hit the tree as hard. At any rate, the number of impacted races does not change the good principle behind the system.
S/ST 51 S/C 53 |
#47 |
#48 |
Liked 120 Times in 42 Posts
#49 | |
Liked 101 Times in 52 Posts
Installing it would seem to even the playing field and I don't think it would take spectators long to understand it. |
#50 |
Liked 7 Times in 4 Posts
Any of you guys who say that you can clearly see the other guy go red while he leaves first , Clearly do not have a clue..
Bob Aceves, 746 E/SA A&M motorsports |
