Old 01-16-2016, 10:21 PM   #1
Liked 5,120 Times in 1,951 Posts
Talking Re: 79 Mustang project U/SA
Originally Posted by Mike Graham View Post
Trying to catch up to the Monti before Tucson. Gotta take that pole from you.
This sounds like a challenge...and a thread hijack
Old 01-16-2016, 10:57 PM   #2
Jeff Stout
Liked 704 Times in 281 Posts
Default Re: 79 Mustang project U/SA
Please go for it. I think the Maverick needs hp as it will help me and robbie racer
Old 01-16-2016, 11:33 PM   #3
National Open..Run what you brung and hope you brung enough..You know..like Chicago
Old 01-17-2016, 11:07 AM   #4
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
It's ok Mark. I'm looking for advice and motivation. I got to build it right the first time and kick all there butts...LOL
Old 01-17-2016, 11:54 AM   #5
Mike Graham
Liked 341 Times in 67 Posts
You can build this thing right without spending a million bucks. Hope to see you out there soon. You and BJ can gang up on the wagon.
Mike Graham is offline   Reply With Quote
Old 01-17-2016, 12:02 PM   #6
Jeff Stout
The Ford gang throwing out the gauntlet. The 4200lb tow vehicle against the little Fords. This will be fun.
Old 02-01-2016, 08:01 AM   #7
RobbieRacer
Well I made some good headway over the last week. Picked up some old school Centerline wheels, a 5 lug disk brake front set up from a 94 GT, ordered upper and lower control arms and Mike Graham is going to sell me BJ's C4 with a low 1st gear and a Mark Yacavone converter.Next weekend will be a busy one. Lot's to do.
Old 02-01-2016, 10:14 AM   #8
SSGT Mustang
Liked 204 Times in 54 Posts
The '94 brakes may not be legal. I thought that the '94 went to a different spindle type, which may cause a problem. I don't know, but you may want to check if making the spindle change is considered cross-breeding parts. It may not matter, since aftermarket brakes are allowed. However, the spindles as I recall are very different from the 79-93 spindles, as are the rotors.
If you do run into problems, I have a set of 5 lug rotors and gt calipers that I would donate to you. You have to pick up the shipping costs. I had the caliper pistons coated by Swain, and solid inserts installed. The rotors have 1/2" long studs and new bearings. They spin pretty well.
They're available to you if you need them.
SSGT Mustang is offline   Reply With Quote
Old 02-01-2016, 11:47 AM   #9
RobbieRacer
They are supposed to be a direct bolt in, but if it turns out that I can’t use them I will just take them back. I was going to get 87-93 spindles and run 5 lug rotors, but thought this set up was better. I’ll have to look into it a little deeper.
Thanks for the offer.
Old 02-07-2016, 12:42 PM   #10
RobbieRacer
I'm finally getting some work done. Rear end out, cleaning up the sheet metal. Pulling the front end apart. Nasty greasy mess. Got a great deal on the rims. I cant remember the last time I saw Firestone Drag 500 tires. I like the old school rims.
Name:	0207160901 (800x600).jpg
ID:	32370   Click image for larger version
Name:	0207160902 (800x600).jpg
ID:	32371   Click image for larger version
Name:	0207160902a (800x600).jpg
Name:	0207160903 (800x600).jpg
