Old 01-15-2016, 09:22 PM   #1
FED 387
Liked 333 Times in 180 Posts
Default Ford 7.3 Power stroke diesel ???
Got a 2000 Ford 7.3 PowerStroke Diesel---- Got a bad glow plug or 2--- getting hard to start and smokes WHITE when cold is there a sure fire way to check and see exactly which glow plug is bad WITHOUT having to pull the valve covers??? If i'm going to go thru all that work I will replace every glow plug if I end up pulling the covers--- thanx ahead of time FED 387
Old 01-15-2016, 10:56 PM   #2
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: Ford 7.3 Power stroke diesel ???
Pulling and replacing all, along with wiring that goes through valve cover is the best way. After changing 1 or 2 twice it was better to do all and be done.
Old 01-16-2016, 07:02 AM   #3
Mark Callanan
Liked 64 Times in 14 Posts
Are you sure it isn't the glow plug relay?
We have a 1997 and we have to replace the relay every couple of years
Mark Callanan 1027 STK
Mark Callanan is online now   Reply With Quote
Old 01-16-2016, 07:41 AM   #4
Thomas S
Check this guy
https://www.youtube.com/user/DieselTechRon/videos
Thomas S is offline   Reply With Quote
Old 01-16-2016, 10:21 AM   #5
Jeff Stout
That is true it could be relay. Easy to check as its in front of motor in lifter valley. Also if glow plug is bad on 1 side of motor you could just do that side. A little starting fluid will work. Its not recommended but will get you out of trouble instead killing batteries trying to start.
Old 01-16-2016, 12:10 PM   #6
FED 387
Should have stated its a 2000 Turbo diesel ---already replaced the relay -helped when it was cooler out now that its cold won;t start without a small shot of ether -- runs smooth when it warms up -- starts well after it has been run and is warm and then restarted----replaced wiring harness UNDER the valve covers last year----there has to be an easy way to test the glow plugs WITHOUT going thru the hassle of dismantling the engine to do it---can you test thru the harness on top of the v cover and so what readings am I looking for that could narrow it down to maybe just one--- it I pull the v Covers to check it I am going to replace EVERY glow plug at that time not worth the time and effort to do just one plug---please keep those suggestions coming---FED 387
Old 01-16-2016, 02:36 PM   #7
Jeff Stout
I thought they can be checked with ohm meter when still on motor. Not for sure. I think the forum to go to is powerstroke.org
Old 01-16-2016, 05:16 PM   #8
Thomas S
I have used Diesel Tech Ron on you tube he is the best , I had to change my hpop on my -03 6,0 he has an video on how you do the work, this guy is the best on information on videos. On the latest video he shows how to check glowplug problems.
Check the link
Old 01-20-2016, 09:32 PM   #9
Johnny U
You can check the glow plugs without pulling the v/covers. You should have no more than 2 ohms resistance on a good glow plug. Also if the motor runs rough until the engine is warm then you might have a few sticky injectors. Also in colder weather you should run 10w30 engine oil. hope this helps some.
Johnny U is offline   Reply With Quote
