Old 01-15-2016, 08:57 PM   #21
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: Roller Cams in Stock Eliminator?
From the comments, glad running Pure Stock...!
Lot of racers having a tough time with 8000rpm flat tappet hydraulic lifters.
What about a limit on Valve Spring Pressure.
Saying that!
What would make common sense?
or
Should racers be doing that anyway?
Dan
Common Sense......HA.....HA.....HA.....HA.....HA.....HA.. ...HO.....HO.....HO.....
Bob Mulry 7516 STK
A & M Motorsports
Old 01-15-2016, 10:24 PM   #22
GarysZ24
GarysZ24's Avatar
Liked 242 Times in 95 Posts
Unhappy Re: Roller Cams in Stock Eliminator?
There hasn't been too much "stock" about Stock Eliminator for quite a while now. Jus sayin'...
There is where my car is concerned, starting with my exhaust manifolds....no headers on my engine, primarily because no one makes them for it.
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
Old 01-16-2016, 12:08 AM   #23
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Slacker
Old 01-16-2016, 12:49 AM   #24
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
OK got a e-mail from NHRA Tech, "no truth to the rumor" on Roller cams . Well got my answer. Thanks everybody for comments, input,
Will Lamprecht I/SA 65 impala
Old 01-16-2016, 12:54 AM   #25
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Rules just make it more expensive, I have 2 new round lobe flat tappet cores being ground right now for my stocker....I could buy almost 10 8620 rollers for the price of those 2 cams, and 4 sets of roller lifters for the 1 set of flat tappets for the cams
carry on
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 01-16-2016, 09:56 AM   #26
james schaechter
Liked 1,438 Times in 301 Posts
I guess if you are looking for headers at a big box store, but why not make a set or have a set made? REF is in Arizona. Maybe they could make a set if you brought the car to them?
James Schaechter 3163 STK
Old 01-16-2016, 10:36 AM   #27
kansas stocker
Liked 249 Times in 48 Posts
Never really understood why the spring pressure rule was overturned. It was easy to enforce on everything but a flathead. Wait were not running those anymore. It made you use your head and not just your pocketbook in several areas. Just my $.02
Pete
kansas stocker is offline   Reply With Quote
Old 01-16-2016, 10:38 AM   #28
Run to Rund
Liked 54 Times in 27 Posts
Originally Posted by john ancona View Post
Every time the subject of roller lifters for stock, someone suggest running Superstock ,It appears that there were a number of gentleman that wanted these changes over the past 30 years, Aftermarket Heads, Intake, Pistons ,Push Rods, Valves, Camshaft, Valve Springs, Retainers, Connecting Rods, Piston Rings, Crank Shaft, Engine Block, Oil Pan, Lifters, Roller Rockers, etc., Aftermarket parts have helped every body in stock eliminator achieve performance gains as well as durability along with a alternative to in some cases 50 year old OEM parts . Who will be the first to go back to the OEM parts and get run over (Flattened) or worse have their engine explode !
After all these aftermarket parts, NHRA considers flat tappets, albeit very non-stock ones, to be the sacred cow making the car "Stock". WOW
Old 01-16-2016, 10:39 AM   #29
Billy Nees
Liked 7,791 Times in 1,745 Posts
^^^^^^^^^^^^^^^^What Pete said too!^^^^^^^^^^^^^^^^
Billy Nees 1188 STK, SS
Billy Nees is online now   Reply With Quote
Old 01-16-2016, 11:00 AM   #30
Dick Butler
Liked 32 Times in 19 Posts
Anyone remember when National records were thrown out because stocker cam 2 or 3 degrees off?
Just Asking?
