Old 01-01-2016, 02:19 PM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: New website: "What class does this run?"
1/1/2016 New stuff for ClassRacerInfo web site!!
  • All the changes from NHRA in the class guides (new power factors) and tech bulletins are in the database.
  • The new F/SAA class added to classifications. (I guessed on the indexes since NHRA has not published them yet.)
  • Fixed some bugs that kept from calculating correct classifications when multiple factors were applied to different bodies of the same model car. This especially affected the 1971-74 Mopar 340 cars.
  • Added panel background coloring for the classification grids so that all the data for a particular engine is easier to visualize on the chart.
  • Added the dates of the power factors to the classification grid.
Currently working on:
  • A way to show odd power factors for the same engine like ram air options, the 63-64 Chevrolets with differences for the WCFB and Rochester carbs, the Chev 454s with the 236 vs the 292 heads, and others.
  • Adding text information for engines and cars. (more on this later!)
Enjoy!!
Dwight Southerland
Old 03-07-2016, 02:47 PM   #2
Dwight Southerland
If you haven't noticed, the AHFS changes from 3/1/16 have been added to the database.
Old 03-08-2016, 09:17 AM   #3
Billy Nees
Liked 7,777 Times in 1,742 Posts
OK? Did you miss the Maverick?
Billy Nees 1188 STK, SS
Old 03-08-2016, 04:33 PM   #4
Dwight Southerland
?? No.
Old 03-22-2016, 07:52 AM   #5
Dwight Southerland
All the changes from NHRA Tech and the AHFS are now in the database:
1) Adding the P5155469 MoPar Performance cast iron replacement head to the 68-89 318, 340 and 360 engines for SS and the 92-02 Dodge truck 318 and 360 engines for Stock.
2) Correction of the head and intake casting numbers for the 77 Ford 302 engines.
3) Addition of another set of carburetors (big ones!) for the 67 Ford 427-425.
4) Horsepower factor change for the 2010 Cobra Jet 352-385hp automatic for Stock.
NHRA's announcements are here - http://www.nhraracer.com/
Old 04-17-2016, 08:40 AM   #6
Tony Corley
Liked 61 Times in 25 Posts
This is an awesome resource, and fun too!! I spend hours sometimes plugging in and comparing combos. Thanks for all of your hard work!
Tony Corley is offline   Reply With Quote
Old 05-12-2016, 08:03 AM   #7
Dwight Southerland
2016 COPO Camaros are now in the database.
Enjoy!!
