Old 12-31-2015, 09:04 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Team Woodfin's Bantam Roadster Build
some details of details
ID:	32064   Click image for larger version
ID:	32063   Click image for larger version
ID:	32061   Click image for larger version
ID:	32065   Click image for larger version
Larry Woodfin 471W
Old 01-01-2016, 07:56 AM   #2
Dragsinger
We are charting new ground [for me] with the usage of a Holley EFI system. The system has two throttle bodies, eight ignition coils, eight injectors, all the normal sensors, data recorder, and electronic dash display.
For me, the EFI lessons are welcome and I will document the learning.
With this buildup the EFI is the star. While the chassis, drive train, body and paint will all be outstanding, show casing the Holley EFI will be the main attraction.
Larry Woodfin 471W
Old 01-02-2016, 07:36 PM   #3
Dragsinger
While Monte worked with the Super 10 block I kept busy with the Roadster's rocker arm set up and pushrod length checking.
*Note the intake lifter and rocker offset
*Note the cylinder head height. The head is a Brodix 11 degree casting worked by Kevin Self. As I began checking the pushrod length I quickly realized this head is not a typical small block head, it is very tall. To establish the proper pushrod length required using a BBC exhaust length checking pushrod!
ID:	32083   Click image for larger version
ID:	32084   Click image for larger version
ID:	32086   Click image for larger version
Larry Woodfin 471W
Old 01-03-2016, 04:20 PM   #4
Dragsinger
#227 shows what can be considered "big lift"
#229 shows the 60 MM cam journal. Monte says it looks like the engine has two crankshafts
#230 shows the cam at 113* per the cam card
#231 cam at 113* and intake valve a full "big lift"
ID:	32092   Click image for larger version
ID:	32093   Click image for larger version
Larry Woodfin 471W
Old 01-09-2016, 10:05 AM   #5
Dragsinger
so you can see part of the vision
ID:	32114   Click image for larger version
ID:	32115   Click image for larger version
Larry Woodfin 471W
Old 01-16-2016, 08:47 PM   #6
Dragsinger
I like beautiful and shinny parts. Check this outstanding work by Dan Olson oil pans.
ID:	32221   Click image for larger version
ID:	32222   Click image for larger version
Larry Woodfin 471W
Old 01-17-2016, 08:35 PM   #7
Dragsinger
A good work day - planning day for the Roadster
ID:	32238   Click image for larger version
ID:	32239   Click image for larger version
ID:	32241   Click image for larger version
ID:	32242   Click image for larger version
Larry Woodfin 471W
Old 02-03-2016, 01:28 AM   #8
doglover44
doglover44's Avatar
Liked 499 Times in 236 Posts
Coming along good ! How son you think it will be on track testing ?
Jake Biermann
Old 02-03-2016, 09:37 AM   #9
Dragsinger
Jake, first runs are some months away. many details yet to attend
Larry Woodfin 471W
Old 02-05-2016, 04:17 AM   #10
Dragsinger
this and that progress photos
ID:	32355   Click image for larger version
ID:	32354   Click image for larger version
ID:	32352   Click image for larger version
ID:	32356   Click image for larger version
ID:	32358   Click image for larger version
ID:	32359   Click image for larger version
Larry Woodfin 471W
