Old 12-29-2015, 11:01 PM   #1
mike britt
Liked 66 Times in 31 Posts
Default 3rd gen camaro rearend
Did GM ever put a bigger rear in a 3rd gen Camaro than the 7.5 in. that's in my 90 IROC?
mike britt is offline   Reply With Quote
Old 12-29-2015, 11:12 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: 3rd gen camaro rearend
Mike,
no, and it would have been a great thing if they had.
For a stocker build a 12 bolt housing bolt in upgrade is the usual option.
Larry Woodfin 471W
Old 12-29-2015, 11:25 PM   #3
mike britt
So I 'll have to go aftermarket, Moser, Strange. Are those legal for stock?
Old 12-30-2015, 12:33 AM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Some Pontiac Firebirds, and Trans Ams came with a 9 bolt "Australian" rearend, which I think was a Dana 44 .
ss3011 is online now   Reply With Quote
Old 12-30-2015, 03:47 AM   #5
Dragsinger
Mike,
aftermarket replacement housings are OK.
Larry Woodfin 471W
Old 12-30-2015, 08:38 AM   #6
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
There was actually a Dana 44 availalbe for a short period of time in the '83-'86 time frame. I have seen a couple, but they were OTC and few were sold.
Old 12-30-2015, 02:06 PM   #7
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
the aussy 9 bolt is stronger than you would think, in 88/89 I had strange make a set of axles for it, lack of gear ratios was a downfall but the car did run well into the nine sec range at almost 145 mph at 3700#'s
unless the car has it already (the OP does not) I would not waste my time with that though when better housing choice are available
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 12-30-2015, 10:38 PM   #8
mike britt
Thanks guys for the info. I have all winter to think about a rear end for this thing, it's one of the last things I'll have to do anyway.
Old 12-31-2015, 06:29 PM   #9
brian schuetta
Liked 28 Times in 15 Posts
If you can find a 69',70' Chevelle rear end they will fit with a little fabrication. They are an inch shorter backing plate to backing plate than a stock Camaro 7.5. I went this route when money was tight 15 years ago. If you have the money just go with an aftermarket piece. I used the stock axles and mini spool with steel caps for a couple years then went to Moser axles and spool. As I remember the cost then with mounting and rear end cost was $540 before the mini spool that used the stock carrier. Good Guys Race Cars in Houston did the work.
brian schuetta is offline   Reply With Quote
Old 12-31-2015, 10:19 PM   #10
mike britt
How strong is the 7.5 rear end? will it stand up to a 305? The lowest gear I can find for it is a 4.56, not sure if that'll be enough.
