Anyone ever tried them on the same motor and noted the ET or HP differences?
I have run the 327 in SS trim that uses 4gc or Q-jet and found the difference is accurately reflected in the HP factors. My motor is low budget.
I spoke to a racer who uses the 327 back and forth between the Holley and Q-jet he claimed Holley was a little quicker . ---Trevor |
Liked 308 Times in 103 Posts
Only comparison I have is I test my Q-jet against 850 dbl. pump holley,just out the box carb on my 305 dynoed pretty much same all the way through the pull,holley made 3lbs more tq. @ peak tq..
Then later had a 351C 4bbl head street/strip engine put my q- jet on it and got same results as the 305 identical except about 3lbs. tq. difference @ peak tq. Not really what you asked but maybe help some how. Mike Taylor 3601 |
#4 | |
Liked 184 Times in 113 Posts
It was flow tested and had new Air Bleeds and new parts. It ran a little better than the ones I reworked. Just felt better, crisper, no bogging. Dan |
What is the"585 Holley" and what combination did it come on?
Thanks, Gary Howe,
Custom construction |
585 CFM Holley and I believe it was on 327 in Corvette's for a few years in the 60's. I'm not sure of the exact details because I have never ran this before. Just word of mouth.
Liked 99 Times in 60 Posts
The "585" Holley was on a 1966 Corvette 327/300. Quick Fuel builds a legal replacement #VS585R
I have it on my Super 10
Larry Woodfin 471W |
Liked 171 Times in 36 Posts
Liked 328 Times in 80 Posts
The 585 was used on the Corvette 327/300 66/67 a 585 was also used on the 350hp engine in 65/66 it had jet plates on both ends. The carb we are talking about has 1 9/16" throttle plates. Don't confuse this carburetor with the 66 chevy II and others with 275 hp and a holley it only has 1 1/2" plates.
We use the 67 327/300 comb in the Sunfire my son drives. In our case the holley is better due to the hp factor, but may not work as well in all cases. Ernie Neal SS 354 |
#10 | |
