Old 11-28-2015, 12:01 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Street Rod fuel question
Guessing it prefers the idle fuel adjustment screws backed out further than the normal 1 1/2 turns or so? Carter AFB style carb? With a larger cam, with those carburetors it is not uncommon to need to drill the idle fuel restrictions out to .035" will usually get it.
Ed Wright 4156 SS/JA
Old 11-28-2015, 12:22 PM   #2
Kegracing
Few more questions:
You said "recently" you have had to use choke to idle it. So that means that this carb and setup did work fine until recently?
In park or out of gear, does the idle speed/rpm go up without the choke on? What does the rpm do when you pull the choke on?
What about timing? Does it use vacuum advance or locked?
Ken
Stock 412
Kegracing is offline   Reply With Quote
Old 11-28-2015, 01:56 PM   #3
Dave Gantz
Liked 251 Times in 125 Posts
If it ran okay at some point in the past, you might want to check for a vacuum leak, as previously mentioned, by either slowly closing the choke flap or covering the air horn with a rag and see if it smooths out. If it does, you can use propane (Unlit!) to try to determine where it's leaking. Don't forget to check the brake booster, if any.
If no leak, pour some Seafoam (I've had success with this product on small engines.) or other gas additive, in a heavy dose in the tank. Drive it a while. A vehicle that doesn't get driven much may have some build-up of crud in the carb.
A carb rebuild may be necessary if it is crud and Seafood doesn't get it clean.
Old 11-28-2015, 01:57 PM   #4
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
Thanks for the ideas guys. It is vacuum advance HEI distributor.....that reminded me, I just replaced the distributor a while back. When ya only drive it once a week or two...the memory gets bad. Now I am thinking that the advance in the distributor might be "walking" around....the idle adjustments make very little difference. Now and before at 1and 1/2 turns. Think I will watch college football today, then tackle the problem tomorrow.
Thanks again,,,
GOT IT....I took the vacuum line off the distributor and now it idles and rumbles like it should. So a distributor or timing issue. Not fuel. Awesome.
Thanks, I would have tank out, changed carburetor and stuff laying all over the place....thanks
Old 11-28-2015, 03:14 PM   #5
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I had a similar problem in the 302 in my street rod Mustang. I took a look in the MSD distributor and the advance cam had unscrewed itself and was bouncing around the bottom of the distributor.
Dale
Dale Shearon
68 Mustang 6394
Old 11-28-2015, 04:26 PM   #6
SStockDart
SStockDart's Avatar
I couldn't stand it....I had to go take cap and rotor out. Found nothing wrong. Springs are fine and the mechanical advance works fine. It runs perfect now....rev it up then let off....comes right back to 800 RPM each time. Think I'll go for a ride, lol. Thanks again.
Old 11-28-2015, 07:58 PM   #7
GTX JOHN
Liked 2,487 Times in 698 Posts
Since you mentioned the distributor change..........It sounds like that might be
the issue. A lot of Hot rods when you put into gear it lowers the RPM enough
that the plate moves and takes out timing. Play with the weights in MSD or for
testing only lock out the curve complete and see if that cures it. Then you know it is a spring problem.
There are bushings in the plate that can easily
be changed to give more initial advance and less advance in plate. My street cars like more initial
and less in plate = 9 Degree bushings (18 engine).
Of Course I am a Mopar guy......Your experiences may vary!
John Irving
741 Stock
741 Super Stock
Old 11-28-2015, 11:24 PM   #8
Kegracing
Glad that fixed it Gary!
I had an HEI do that and drove me crazy years ago... was that ghost that made me start locking out all my distributors or doing mechanical advance only.
Ken
Stock 412
