Liked 354 Times in 120 Posts
Need a carb id and what it would have come on. 7028210 Q Jet, was on a 69 chevelle 325 / 396 auto nov 68 production date, is this the correct carb for this app? Tom
Tom Meyer 5240 SS Stock ??? |
Liked 10 Times in 5 Posts
it's for a 68 385hp 727 auto
Liked 284 Times in 87 Posts
Tom…1968 Camaro 396-325HP with Automatic. MB
#4 | |
Liked 684 Times in 289 Posts
here is a link: http://quadrajetparts.com/decode-you...retor-t-5.html another site I went to agreed with this looks like 68, non California, automatic trans. didn't see engine / model specific info. Good Luck Mike A114 P/SA |
a 1968 396/325 hp is a 7028218. you can check NHRA web site under engine blueprint specs. they have the correct numbers
Liked 2,487 Times in 698 Posts
Does the number matter to NHRA as long as internal dimensions are correct?
#7 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
This is for a resto, needs to be the right numbers match that I think now is 702900. Did you know that the min spec has a 15ths grace measurement. Tom
Liked 79 Times in 22 Posts
Rochester Carb. Stamping Codes
First part of stamping number: 702 - Late 1960's 703 - Late 1960's with Air Injector Reactor (some exceptions exist) 704 - 1970-1975 1705 - 1976-1979 1708 - 1980's Then Model Year (i.e., 7=1967, 9 = 1969, 0=1970, etc.) Then Carb. Type 0 - Monojet, Federal Emissions 1 - Two Jet, Federal Emissions 2 - Quadrajet, Federal Emissions 3 - Monojet, California Emissions 4 - Two Jet, California Emissions 5 - Quadrajet, California Emissions 6 - VariJet, Federal Emissions (2 barrel) Then Division of GM 0, 1, and 2 were all used by Chevrolet (2 used on Cadillac also). 3 - Cadillac 4 - Buick 5 - Olds 6,7 - Pontiac Then transmission type 0,2,4,6,8 Automatic Transmission (some exceptions exist) 1,3,5,7,9 Manual Transmission (some exceptions exist) On some carburetors there is a production code (usually a two letter code) stamped below the numerical ID code. On some carburetors there is a manufacturing date code below the production code. Example: 2277 would indicate the 227th day of 1967 or 1977, depending on the year specified in the ID code. |
