Old 11-25-2007, 01:14 PM   #1
Liked 1,929 Times in 434 Posts
Default Re: Oil Passing By Rings
Correct. If you want a Speed Pro Dykes ring set, you have to "build" it from "open stock" rings.
Total Seal will make most anything you want, but Keith Jones (the guy I work with at Total Seal) is not a fan of Dykes rings. Keith will likely advise you to go metric with spacers, and put a custom low tension Speed Pro SS-50U series oil ring together. But he WILL do a Dykes setup if that's what you want.
Old 11-25-2007, 02:49 PM   #2
RICK W
Thanks Guys
RICK W is offline   Reply With Quote
Old 11-26-2007, 10:37 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
Rick,
You should have 15 lbs of drag on the piston with the oil rings installed. If you can install the piston without a ring compressor you have the wrong rings. Install the piston in the bore up side down and attach a fish scale to the large end of the rod and pull the assembly up the bore and read the resistance in pounds. You should have about 15 to 18 lbs. Anything less and you will get oil past the rings. Once you find a good set of expanders keep them and only replace the rails on the oil ring when you are freshening your engine
Mike
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 11-27-2007, 12:39 PM   #4
RICK W
Thanks For The Info Mike
